Thread: swapped engine and trans now wont start
Results 1 to 6 of 6
  1. #1 swapped engine and trans now wont start
    GT Level Member titanfan12's Avatar
    Jan 2013
    west palm
    ok well I swapped my 99 3.8sc and trans into an 02 body which i removed the engine and trans from. Now here I am done and I go to start it and nothing. I checked the trans bell houseing and my wires are on good, so I check the starter and its getting power (stuck a flat head between the 2 bolts to make sure I was getting power).Spark plugs and injectors are also on properly. one thing I have noticed is when i turn the key over security flashes and the radio flashes off when i hold the key over and when I turn the key back its back on. fuel pump kicks on. Engine and trans i put in are very good, i got tboned in my other car and put my engine and trans into this 02. Any help would be nice
    99 Silver Gtp here --------------------> http://www.grandprixforums.net/my-99...gtp-80323.html
    slp headers ,straight pipe, intriuge suspension, cai, ported tb, performance roller lifters, and bulit trans. 04+ seats in and le spoiler on
  2. #2 Re: swapped engine and trans now wont start
    did the old engine crank over or even start?
    sounds like a security issue with a dash of ignition harness maybe.
  3. #3 Re: swapped engine and trans now wont start
    Jan 2013
    west palm
    yea the engine i took out was running but very poorly and how would i go about the security issue?
  4. #4 Re: swapped engine and trans now wont start
    pretty sure you need a tech 2 scanner to do that.
  5. #5 Re: swapped engine and trans now wont start
    Feb 2009
    flintnasty MI
    google security relearn? you have NEVER needed a tech2, why would you just guess to make this guy go on some stupid chase to find one????? Dick.
  6. #6 Re: swapped engine and trans now wont start
    i can take a correction with being called names. we've never had a problem with each other before, why start now?
  1. Swapped engine, trans, and pcm now no start
    By mrlogic1234 in forum General Tech Discussion
    Last Post: 09-23-2013, 07:05 PM
  2. Topped swapped 06 GP now wont start and scan tool wont comm with ECM
    By jbrltoliver in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-31-2013, 08:36 AM
  3. Engine wont start
    By Hixc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2011, 08:51 AM
  4. rough engine then wont start
    By RyanL in forum General Tech Discussion
    Last Post: 06-06-2010, 03:32 AM
  5. Top Swapped 06- Wont start
    By Crispix396 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2010, 09:05 PM
