My power steering was making a horrible whining noise so I changed out the power steering pump and noticed my rack was leaking so I went ahead and changed that out as well. Now I bled it with the wheels off the ground and drove it around. It still made the whining sound when I would turn the wheel. I tried bleeding it again with no sucess. I drove it a couple of days hoping it would work itself out. The fluid level was were it was suppose to be. But the sound just kept getting worse. I ended changing the pump out again, under warranty, and this time I figured I bleed it really good before I drive it. I have it up on jacks right now and turned the wheel back and fourth many atimes. Turned the car on for 2 seconds and checked the fluid. Saw a bunch or white foamy bubbles. So I bled it again. Did that process all night last night. And it seems like the bubbles are not going away. If I leave the wheels turned all the way in either direction, with the car off, and I look at the fluid I can see little air bubbles come up. I watch it for several minutes and I still see the little air bubble come up. So my question is, am I doing something wrong? Why am I getting so many air bubbles? The fluid is not dropping any. And I did flush out the old fluid. Can something be causing air to get in the system?
