Thread: Northstar on L67 w/ Gen V question.
Results 1 to 3 of 3
  1. #1 Northstar on L67 w/ Gen V question.
    Jun 2013
    N/A
    I read many of the writeups about the topic, but one thing I'm confused on is what wire adapter harnesses do I need to buy to make this work?
    I have right now the LQ4 MAF.
    These are what I need to purchase?
    Gen V adapter plate
    MAF harness OR MAF with the IAT?
    TPS Harness?
    Custom cruise bracket?
    00+ N*
    Thanks!
  2. #2 Re: Northstar on L67 w/ Gen V question.
    Gen V adapter plate, yes
    Either of the maf harnesses will work. The LQ4 has a built in IAT sensor, so you don't have to run your factory one if you choose the adapter with the IAT. Up to you, you need one of them though.
    TPS, yes
    Custom cruise bracket.. I modify the stock brackets and it works well, if you don't want to work..buy the bracket.
    00+ N* keep in mind there are a lot of these at JY's very cheap. Before you pay a mint.. check it out.
  3. #3 Re: Northstar on L67 w/ Gen V question.
    Jun 2013
    N/A
    Thanks for clearing things up, Bill.
    Are there any benefits running stock IAT vs LQ4 IAT & vic-versa?
  1. Northstar & MAF Question
    By dbextreme in forum General Tech Discussion
    Last Post: 02-26-2013, 06:37 AM
  2. Northstar throttle body question?
    By XtrmGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-23-2012, 09:57 PM
  3. GP Northstar v8
    By DDPeppa in forum Off Topic Discussion
    Last Post: 12-21-2010, 05:17 PM
  4. which northstar map to buy? help
    By copperpacecar in forum General Tech Discussion
    Last Post: 02-18-2010, 08:54 PM
