Gen V adapter plate, yes
Either of the maf harnesses will work. The LQ4 has a built in IAT sensor, so you don't have to run your factory one if you choose the adapter with the IAT. Up to you, you need one of them though.
TPS, yes
Custom cruise bracket.. I modify the stock brackets and it works well, if you don't want to work..buy the bracket.
00+ N* keep in mind there are a lot of these at JY's very cheap. Before you pay a mint.. check it out.
