Thread: Oil Leaking
Page 1 of 3 123 LastLast
Results 1 to 20 of 54
  1. #1 Oil Leaking
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    Alright, 1999 Grand Prix GTP stock other than ZZP Downpipe.
    Car is having a cylinder 3 misfire at the moment. I removed the sparkplug and it appears to be quite oily. I was driving home tonight and All of a sudden the car started running like crap and then the Service Engine light started flashing which I know is indicating a misfire happening at the time. I checked that plug and noticed oil like all over the front of the engine and everything. Also saw that my dipstick was pushed up a few inches. I checked and was just about out of oil so I put some oil back in it and cleaned the spark plug and put it back in but still have the cylinder 3 misfire. I checked cylinder 1 and 5 plugs too and they were also fowled looking, like they were all dipped in oil. I checked cylinder 4 plug and it was the same way. I assume that cylinders 2 and 6 will probably be the same. With all this, still only a cylinder 3 misfire. Just looking for some thoughts?
  2. #2 Re: Oil Leaking
    Maybe the PCV is plugged, kinda sounds like it to me if its eating oil and the dipstick got pushed up a little.
  3. #3 Re: Oil Leaking
    Aug 2011
    Michigan
    Good idea, how would I check that. Not sure where the PCV valve is
  4. #4 Re: Oil Leaking
    PCV valve is in the supercharger. Black cap with 2 bolts holding it down, can't miss it.
    You can do the shake test to see if you hear it rattle, but for the 3-5 bucks that they cost I'd just replace it.
  5. #5 Re: Oil Leaking
    Aug 2011
    Michigan
    Interesting. Alright, I know where you're talking about. But do you have an idea as to why cylinder 3 is misfiring? I have another spark plug I could put in its place, but I'm concerned about me putting in another spark plug and it instantly getting ruined like the current one and causing a misfire again. And, I live about 15 minutes from town and have work at 6am and classes throughout the rest of the day >.<
  6. #6 Re: Oil Leaking
    Aug 2011
    Michigan
    Update. I did replace that spark plug and to no avail. Put a new one in it's place and instantly the problem returned with cylinder 3 misfiring. Still only cylinder 3. The plug I pulled out of cylinder 3 was drenched in oil too.
  7. #7 Re: Oil Leaking
    do a compression test. the rings maybe blown causing blow by. if the oil dip stick was pushed up thats never a good thing.
  8. #8 Re: Oil Leaking
    Aug 2011
    Michigan
    I had a compression test done about a week and a half ago, they said the compression came back fine. I will see if my grandpa has his compression tester still and do the test myself. If the compression is low, what could be the causes of that?
  9. #9 Re: Oil Leaking
    bad rings on the pistons, or chipped pistons. but you'd have smashed plugs on every cylinder already if the pistons chipped.
    or the pvc is blocked solid.
  10. #10 Re: Oil Leaking
    I suppose you could pull the oil cap off and see if you get a massive draw of air in or out of the engine.
  11. #11 Re: Oil Leaking
    Aug 2011
    Michigan
    I was looking for the PCV on Autozone's website and wasn't seeing anything that looked like it would be the part I needed? But then again, I'm not sure what the part looks like. I was thinking about, if my car was driveable, going to Autozone tomorrow and just pulling the part out in their parking lot and taking it in and matching it up. But I'm not sure I want to drive my car too, and all around town with cylinder 3 misfiring. The car is running quite rough.
  12. #12 Re: Oil Leaking
    Aug 2011
    Michigan
    I did that for a few seconds and yes, there was some puffing and the engine seemed to bog down a little bit when I took it off. It sounded like it was sucking and blowing air in and out.
  13. #13 Re: Oil Leaking
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Replace your PVC
    I went NA when a whore left -$300 in my bank account.
  14. #14 Re: Oil Leaking
    Aug 2011
    Michigan
    Well, about to check in the morning to see if I have a bad cylinder 3 such as a hole in my piston or anything. Then going to do a compression test on the rest of the cylinders. After that, if everything checks out and if I can get cylinder 3 firing, I'm going to buy a supercharger gasket, upper intake gasket, lower intake manifold gasket, PCV valve, transmission fluid filter, oil filter, oil level sensor, all my fluids, and valve cover gaskets and going ham on Friday. Hopefully I can get all that done within a day o.O because it's pretty cold out. Glad we have Monday off of classes incase I can't get it done on Friday, busy Saturday and Sunday for the most part. Basically dedicating this weekend to my car and going to give it some well needed TLC. Exciting stuff
  15. #15 Re: Oil Leaking
    Aug 2011
    Michigan
    Well so far got everything torn apart down to the heads. Definitely had a bad supercharger gasket and the lower intake gasket was on its way out. It wasn't in the best shape, but it wasn't in the worst shape either. I broke the freaking T under the snout and right were the vacuum line coming from the MAP sensor connects to that T broke as well. Also, the coolant elbow was broke off in the manifold and also in the other connection point. Annnd my grandpa broke the clip to the MAP sensor plug on accident so, got a few things to do and fix on top of putting all the new gaskets on and putting the car back together slowly and carefully. I plan on putting the green coolant in instead of the Dexcrap. Got quite a bit of work ahead of me =P
  16. #16 Re: Oil Leaking
    i did mine in less then 3 hours alone, and taking my time.
    advance auto sells these nice little white T's, a 2 pack for 2 bucks. (you need 2) new vac line is like a dollar a foot.
  17. #17 Re: Oil Leaking
    Aug 2011
    Michigan
    Well it's just about back together. Don't have a garage so got it in the unheated barn and in roughly 18* weather, took a bit longer than 3 hours. Like, probably a total of 10 or so but that wasn't straight working on it the whole time. Took a lot of breaks to warm back up and everything. Also, had to run into town to buy some things that my grandpa broke, and the oil level sensor that I forgot to buy the first trip. Pretty excited to have it back together, just gotta change my fluids now. I can't find the radiator plug thing I think because the brush guard is still in the way so I might just undo the bottom radiator hose and get as much out as I can that way. That and an oil change and it should be ready to go!
  18. #18 Re: Oil Leaking
    i found it easier to pull the lower hose from the engine, let the rad dump from there.
    or flush it out the top hose. remove the t stat, take the hose off the upper side of the rad, fire it up the coolant gets pumped out. run the car till its clear coolant.
    if you want full flush directions let me know, its saved on my pc.
  19. #19 Re: Oil Leaking
    Aug 2011
    Michigan
    Thank you, Scottydoggs. You're a manual of information!
    Concern popped up. Put the car all back together, all the sensors plugged back in, all the vacuum lines plugged in correctly, new battery, no start. Turns over with absolutely no problem, but it's as if it's not getting spark or something. I pulled a sparkplug out and left it plugged in and it sparked. A lot of my plugs were bad because of the bad gaskets letting oil in the cylinders so I replaced all 6 spark plugs with new Autolite 606's. Still the same issue. It revs up to about 100rpm and then peaks up to like 150 for a millisecond and then drops back down, it's as if it puffs in some air or something and drops back down to the 100rpm range again and then puffs up again really fast. I just did a re-learn or whatever, turned key to on and pressed gas down 3 times and the service engine light started flashing and the fuel pump kept making noise. Turned it back off and went to turn it back on and same issue. Not sure what to do now. Anyone got any ideas? =/
  20. #20 Re: Oil Leaking
    did you take the coil bracket off the engine? if so, did you put the ground wire on the bolt on the side of the head?
  1. Leaking on the top
    By bull40dawg in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-24-2012, 07:23 AM
  2. Leaking
    By gtpzmdc in forum General Tech Discussion
    Last Post: 08-17-2012, 01:59 PM
  3. Replies: 21
    Last Post: 03-07-2012, 02:10 PM
  4. Leaking oil all under car
    By GTLGDP in forum General Tech Discussion
    Last Post: 01-17-2012, 08:15 AM
  5. On and off leaking?
    By Fraschy in forum 3.4L V6 (LQ1) DOHC
    Last Post: 09-24-2011, 01:11 AM
