Thread: Car bogs down above 15% throttle??? Fuel Pump?
Results 1 to 20 of 20
  1. #1 Car bogs down above 15% throttle??? Fuel Pump?
    Donating Users timboku's Avatar
    Montgomery, IL
    Car bogs down when you give it gas while in drive. If I keep throttle under 15% it runs fine. Give it some gas and it bogs down and is very sluggish. When the car is in nuetral or park you can rev it and it runs fine. No SES light on or anything. New plugs, wires, and O2 sensor recently installed. I think fuel pump is original and it has over 200k on it so that whay I am thinking. Thoughts before I get a new one??
    Fuel Trims are fine at idle but when you gas it they go crazy as well.
  2. #2 Re: Car bogs down above 15% throttle??? Fuel Pump?
    clogged cat? the cel flash yet when flooring it?
  3. #3 Re: Car bogs down above 15% throttle??? Fuel Pump?
    Dec 2012
    Where 4T65E's were born
    Only way to really tell is to hook up a pressure gauge, tape it to the windshield, and take a drive to make sure the pressure stays where it should. Could be a few other things as well but I think you may be on the right path on a fuel issue whether it be the pump or regulator. Could always pull the vacuum line on the FPR and see if it smells like gas as a super quick check. Could be leaking past and bogging it with too much gas (very bad)
    Also just read what scotty said, I just have a question as I really don't know, if the cat is clogged wouldn't that make it hard to rev in park and neutral too?
    Sold.
  4. #4 Re: Car bogs down above 15% throttle??? Fuel Pump?
    not always. once a load is added it wont have power. cats are odd when they die.
  5. #5 Re: Car bogs down above 15% throttle??? Fuel Pump?
    Montgomery, IL
    No cat installed so thats not it. Pulled FPR already no smell. Its just weired that it does not bog down or stumble in park. Just under a load. Do they rent fuel pressure testers??? No CES light on or flashing either.
  6. #6 Re: Car bogs down above 15% throttle??? Fuel Pump?
    Montgomery, IL
    also, what pressure should the pump be at idle and under load? Also, whats a good pump? Was looking at the zzp one for 100 bucks.
  7. #7 Re: Car bogs down above 15% throttle??? Fuel Pump?
    Dec 2012
    I think 45 psi at idle is good. Key on engine off should be the same and stay there, and not drop off. Not sure about under load, probably still in that area.
    Sold.
  8. #8 Re: Car bogs down above 15% throttle??? Fuel Pump?
    Montgomery, IL
    So turned car around to back it in to garage figured I would change the fuel filter just to make rule that out. I hit the schraeder valve on the fuel rail to release the presure and a baby drop came out not under pressure. Bad sign right that should be under pressure so thinking its the pump even more now.
  9. #9 Re: Car bogs down above 15% throttle??? Fuel Pump?
    try again with the key to run,car off. if nothing comes out the pump could be bad.
    what year you have? the high speed relay trick may work. if its got a bad resistor. 97-01 that trick works fot iirc.
  10. #10 Re: Car bogs down above 15% throttle??? Fuel Pump?
    Montgomery, IL
    02 gtp...only single stage pump....it starts right up no problem. Gonna change filter now and see what that does.
  11. #11 Re: Car bogs down above 15% throttle??? Fuel Pump?
    buy a pump while your there getting the filter. if the filter clogged to the point the pump stopped, it killed the pump probably.
    do you hear the [ump whine at all when the key is first turned to run?
    and then theres my fav. bang on the tank bottom with your palm a few times, this can shock it back to life sometimes. if it fires up and runs well the pump is bad
    if it comes down to a new pump, look on line for just a replacement pump, you take your old one out of the sender bucket and install the new one. it comes with a new sock filter hose zip ties and a plug sometimes to power it.
    just replacing the pump is like 30 bucks or less. whole bucket with sender and new pump up to 300.00.
  12. #12 Re: Car bogs down above 15% throttle??? Fuel Pump?
    The Boss Iceman6669's Avatar
    Jun 2011
    Highly recommend going with a walbro/Racetronix pump. Plus that's a great time to do a rewire.
    2011 F-150 Yote powered
  13. #13 Re: Car bogs down above 15% throttle??? Fuel Pump?
    Montgomery, IL
    I have high flow filter from zzp that i will put in. The pump works the car starts and drives no problems. It is when you give it over 20% throttle it bogs down. Who sells the walbro pumps? I have 42lb injectors and a rewire kit to put in so looking for a good pump to go along with it.
  14. #14 Re: Car bogs down above 15% throttle??? Fuel Pump?
    Jun 2011
    Quote Originally Posted by timboku View Post
    http://intense-racing.com/Merchant2/...Code=3800_Fuel
  15. #15 Re: Car bogs down above 15% throttle??? Fuel Pump?
    Montgomery, IL
    pump ordered thanks!
  16. #16 Re: Car bogs down above 15% throttle??? Fuel Pump?
    Montgomery, IL
    Ordered my pump which will be changed out. But any thoughts of this being a MAF issue? When i unplug the maf it doest really change how the car drives. Trims are perfect though and no CES light. gonna try to locate one in the garage and swap them?
  17. #17 Re: Car bogs down above 15% throttle??? Fuel Pump?
    Florida
    Well, the MAF being bad isn't going to cause 0 fuel pressure at the rails. If you have next to no fuel going to the engine, unplugging the MAF isn't going to make a lick of difference, cause the PCM cant get more fuel to the motor.
  18. #18 Re: Car bogs down above 15% throttle??? Fuel Pump?
    Montgomery, IL
    I have pressure at the rail when its running. I still need to the store and rent one to check and i will regaurdless be changing the pump as it has 200k on it already. Its just weried that it runs perfect when you dont go above quarter throttle.
  19. #19 Re: Car bogs down above 15% throttle??? Fuel Pump?
    Montgomery, IL
    Quick update...So changed pump and that helped alot..there is pressure in the lines and starts right up now! but still was sluggish in higher rpms...changed maf..no change..finally changed coil pack module and bingo all fixed..runs sweet....fuel pump rewire tomorrow.
    Sent from my SCH-I545 using Tapatalk
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  20. #20 Re: Car bogs down above 15% throttle??? Fuel Pump?
    sounds good.
  1. 97 GTP fuel pump woes: Rewire stock pump?
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2013, 06:29 PM
  2. NEED RESPONSE QUICK! fuel pump fuse blowing, part throttle hesitation
    By usetaboost in forum General Tech Discussion
    Last Post: 01-02-2013, 08:46 AM
  3. 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    By corvettemike in forum General Tech Discussion
    Last Post: 04-07-2012, 10:04 AM
  4. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
