Thread: Speed Daddy Headers and Smog
Results 1 to 20 of 29
  1. #1 Speed Daddy Headers and Smog
    Jan 2014
    Bay Area CA
    I am thinking about getting these headers for the price I dont know how I could go wrong.
    http://www.ebay.com/itm/STAINLESS-SS...977378&vxp=mtr
    How difficult is the install. 4 hour job?
    Next question. Are these setup to run the stock down pipe? I need two run two cats so I can pass Cali tail pipe emisions.
    Thanks for any help.
    Eric
  2. #2 Re: Speed Daddy Headers and Smog
    from the factory it only came with one cat. then a resonator, then the mufflers.
    ca is messed up with approved headers. you can still run a cat, and the egr vale can still be hooked up. so all the factory sensors are stil used.
    no idea if you pass inspection.
    the other way you can get close to headers and pass inspection is a front plog, and a 3 inch catted down pipe. not as good as headers, but better then stock.
  3. #3 Re: Speed Daddy Headers and Smog
    Jan 2014
    Bay Area CA
    Thanks for the quick reply. Is teh front O2 before or after the cat. I would guess before. So there are EGR provisions on the speed daddy headers? I cannot tell from the picture.
  4. #4 Re: Speed Daddy Headers and Smog
    St. Louis
    Upstream O2 is before the cat.
  5. #5 Re: Speed Daddy Headers and Smog
    Jan 2014
    Bay Area CA
    Will the stock cat or a ZZP down pipe bolt up to the speed daddy kit?
    P.S. Thanks for the quick response.
  6. #6 Re: Speed Daddy Headers and Smog
    headers come with a down pipe. some are sold with a cat, some are sold without one. aka off road pipe its called.
    you can install a cat if the speed daddys headers dont come offered with one.
  7. #7 Re: Speed Daddy Headers and Smog
    Jan 2014
    Bay Area CA
    any recomendations on cats?
  8. #8 Re: Speed Daddy Headers and Smog
    Aug 2013
    McDonald PA
    Quote Originally Posted by bignose94015 View Post
    Well CA state inspection does allow high flow ones. I know magnaflows are 49 state legal. Lol the one state being CA but I think maybe flowmaster just changed theirs to 50
    State legal
  9. #9 Re: Speed Daddy Headers and Smog
    walker are stock replacements, pretty sure thats what ca wants to see, factory parts.
  10. #10 Re: Speed Daddy Headers and Smog
    Feb 2013
    37.295091, -121.930053
    the only set of headers CA will let you ever have is from "The Other Guys" header and you have to tell them your from ca to get your EO sticker.
    http://www.arb.ca.gov/msprog/aftermk...es/amquery.php
    here is a link that will help you out a ton on the hole EO number. From what I looked up last year you couldnt run an IC it was Illegal, also too CA thinks they own your Cat as well you cant touch that if you want to drive on the roads out here.
    had to edit this because i didnt have the right link
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  11. #11 Re: Speed Daddy Headers and Smog
    Jan 2014
    Bay Area CA
    Thanks for all the info everyone. I am not worried about the visual. Only worried about the tail pipe. Just looking for a cheap OB2 50 state legal 3" cat. It appears the speed daddy is a 3" DP.
    Thanks
    Eric
  12. #12 Re: Speed Daddy Headers and Smog
    Jan 2014
    Bay Area CA
    I also thought the other guys were out of business.
  13. #13 Re: Speed Daddy Headers and Smog
    Feb 2013
    last year when i looked it up it said that the other guys header were ca approved but to shell out 899 for a set of headers is way way way to much
  14. #14 Re: Speed Daddy Headers and Smog
    Feb 2013
    here found this on there for ya
    EO: D-509 View PDF
    EO Date: 2001-01-22
    Manufacturer Name: Other Guys Performance Products
    Device: Exhaust Header System
    Device Type: Exhaust System / Exhaust Modification
    Part_Number: Model_Specification: Modification_Allowed: Remarks:
    340022 1998 through 2001 Grand Am 3.1L The Exhaust Header System is manufactured out of 14 gage stainless steel. Connecting pipes are included. The oxygen sensor is located at the header collector.
    350023 1991 through 1999 49-state certified, General Motors 5.7L trucks Same as above
    350023C 1991 through 1999 General Motors trucks 5.7L Same as above
    380021 1997 through 2000 3.8L Grand Prix SE/GT/GTP, Buick Regal supercharged and non supercharged Same as above
    381021 2000 Monte Carlo 3.8L Same as above
    454024 1991 through 2000 49-state certified, General Motors 7.4L trucks Same as above
    454024C 1991 through 2000 General Motors trucks 7.4L Same as above
    498025C 2001 General Motors trucks 8.1L Same as above
    580022 1999 through 2001 49-state certified, General Motors 4.8, 5.3, or 6.0L trucks Same as above
    580022C 1999 through 2001 General Motors trucks 4.8, 5.3, or 6.0L Same as above
  15. #15 Speed Daddy Headers and Smog
    Aug 2013
    McDonald PA
    Look up flowmasters cats I can't find the answer on my phone
  16. #16 Re: Speed Daddy Headers and Smog
    Jan 2014
    Bay Area CA
    Not that I would do this but does anyone have a picture of the EO number on the header? I have a guy that makes stainless steel identification plates...
  17. #17 Re: Speed Daddy Headers and Smog
    Jan 2014
    Bay Area CA
    In theory I should be able to jsut weld me stock cat in correct? What is the difference in size between the SD down pipe and stock down pipe. If I remember correct the Stock DP is 2.25 ID.
  18. #18 Re: Speed Daddy Headers and Smog
    Feb 2013
    from what i have heard the EO number is nothing more than a sitcker
  19. #19 Re: Speed Daddy Headers and Smog
    Never Never Land
    Couldn't you get SLP headers that will pass CA specs? Since those could come factory on the car.
  20. #20 Re: Speed Daddy Headers and Smog
    Feb 2013
    they want that little sticker with some numbers.
  1. speed daddy headers
    By t wizzle17 in forum For Sale - Parts
    Last Post: 09-01-2013, 06:14 PM
  2. speed daddy headers
    By sic40th in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2011, 05:07 PM
  3. Speed daddy Headers...
    By Vlad0691 in forum General Tech Discussion
    Last Post: 01-17-2011, 01:09 AM
  4. speed daddy headers
    By PONTIACGTP05 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2010, 10:54 PM
  5. Speed Daddy Headers
    By Vioarr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2010, 03:29 PM
