Thread: Speed Daddy Headers and Smog
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: Speed Daddy Headers and Smog
    Jan 2014
    Bay Area CA
    Last question of the night. I want to run mid to low 13's. Woulld necking down the SD down pipe to the Stock cat be to much of a restriction?
    Thanks,
    Eric
  2. #22 Re: Speed Daddy Headers and Smog
    if you were to get a 3 inch dp, its gonna get reduced to the 2.25 pipe when it bolts to the cat back. its fine.
  3. #23 Re: Speed Daddy Headers and Smog
    Jan 2014
    Bay Area CA
    Ah, So the SD kit does not come with a DP. I will need to order one from ZZP.
  4. #24 Re: Speed Daddy Headers and Smog
    ALL HEADERS COME WITH A DOWN PIPE.
    its your choice with most brands if you want a 2.5 or 3 inch DP, catted or no cat with your header order.
  5. #25 Re: Speed Daddy Headers and Smog
    gardner,mass
    Lets make this easy. Sd headers come with a straight downpipe no cat that bolts to the stock resonator assembly.
    See the 3 pipes on the bottom? The straight pipe, the flanged pipe and the one with the bend in it? Those are 3 inch and are the downpipe. They clamp together and clamp from the flex on the rear header to the flange on the res assembly.
    Now the straight part of this can be replaced with a 3 inch cat. Your best bet is to get it welded in. Just go to your local auto parts store and ask them for a 3 inch cat that would be cal compliant.
    Speed Daddy Headers and Smog Attached Images
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  6. #26 Re: Speed Daddy Headers and Smog
    Jan 2014
    Bay Area CA
    Thanks guys. Still getting used to the GTP world.
  7. #27 Re: Speed Daddy Headers and Smog
    It comes with its own downpipe
    04 Comp G.
  8. #28 Re: Speed Daddy Headers and Smog
    Hey guys, just incase nobody said it, they do come with a downpipe.
    Figured I'd help out.
  9. #29 Re: Speed Daddy Headers and Smog
    Jan 2014
    Bay Area CA
    Lol. Thanks
    Sent from my SCH-I535 using Tapatalk
  1. speed daddy headers
    By t wizzle17 in forum For Sale - Parts
    Last Post: 09-01-2013, 06:14 PM
  2. speed daddy headers
    By sic40th in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2011, 05:07 PM
  3. Speed daddy Headers...
    By Vlad0691 in forum General Tech Discussion
    Last Post: 01-17-2011, 01:09 AM
  4. speed daddy headers
    By PONTIACGTP05 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2010, 10:54 PM
  5. Speed Daddy Headers
    By Vioarr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2010, 03:29 PM
