Thread: Question about LTFTs
Results 1 to 20 of 29
  1. #1 Question about LTFTs
    Florida
    Just got done installing my WBS intercooler on the car. I ended up deleting the EGR and I am currently still running a stock PCM. (I've got an Intense tuned PCM ready to go in once I get my injectors)
    At idle with the engine cold, LTFTs are around -15 to -16.4 bouncing around between those two values
    At idle with the engine at operating temp, LTFTs stay around -10 to -12.
    Normal driving they bounce between -5 to -11
    Cruising at 60mph it will stay around -10.5 to -11.1
    WOT stays at 0
    No vacuum leaks, no exhaust leaks.
    STFTs stay between -2 to +3 at all times, and stays at 0 during WOT.
    My question is; Are my LTFTs wacky due to the EGR delete, or is there possibly something else going on?
  2. #2 Re: Question about LTFTs
  3. #3 Re: Question about LTFTs
    It might not be a huge vac leak, but it's possible with the IC.
    Those are some pretty beefy trims, lol.
    Are the MAF tables correct (i.e. matching year MAF/TB)?
  4. #4 Re: Question about LTFTs
    Florida
    I know I'm running rich.
    Vacuum is between -22 in/hg to -19in/hg fluctuating with the rpms.
    PCM is stock. Not been messed with at all. Running a stock L67 MAF and TB.
  5. #5 Re: Question about LTFTs
    the intercooler is giving you a lot more headroom with the fueling and the stock tables are way off now. you're running rich.
  6. #6 Re: Question about LTFTs
    He is cammed, I blame that for the fuel trim problem.
  7. #7 Re: Question about LTFTs
    Florida
    LTFTs were no where near that far off with only the cam. Cruising they would stay between -1 and +2.
  8. #8 Re: Question about LTFTs
    Florida
    Makes sense.
    Time to run around with the slowest cammed/intercooler setup ever, yay.
  9. #9 Re: Question about LTFTs
    My XP car idled between -15-17 in/hg~.
    That's not too far off, but yes...stock car idles around -20~ give or take one or so. Cam doesn't make THAT much of an impact.
    It needs tuned too. Get wideband
    Until then, throw on a 2.8" and let me race you in a really slow car.
    Also, what about an exhaust leak? How'd you seal the IC? Is the PCV working?
  10. #10 Re: Question about LTFTs
    Florida
    Wideband is currently at AEM getting repaired under warranty. Should be back next week.
  11. #11 Re: Question about LTFTs
    Squidy McSquiderson.
    Answer my questions, I edited my post.
  12. #12 Re: Question about LTFTs
    Florida
    Have pictures
    Though I had a good pic of the PCV setup. Drilled and tapped the brass plug in the TB, got that running to the Gen V PCV port.
  13. #13 Re: Question about LTFTs
    Florida
    Operation ****s and giggles is on. Be back in a min.
  14. #14 Re: Question about LTFTs
    Florida
    But I like my 3.8 pulley. We've been together for so long.
    Car had an exhaust leak at the crossover. Got it welded and no more leaks.
    IC is sealed with RTV, top and bottom.
    Breather on the front, PCV is working fine for the rear.
  15. #15 Re: Question about LTFTs
    Put the oil cap back on for S&G's.
  16. #16 Re: Question about LTFTs
    I thought breather was there for non-working PCV?
  17. #17 Re: Question about LTFTs
    God ****ing damnit.
    **** YOU SQUID.
    Go take the JB weld out of that case you nub.
  18. #18 Re: Question about LTFTs
    I live here. DirtDog's Avatar
    Jun 2012
    Let's play guess what's wrong with the GM!!
  19. #19 Re: Question about LTFTs
    IT'S THE BEST GAME.
    eva.
  20. #20 Re: Question about LTFTs
    Jun 2012
    I'm terrible at it
  1. brake part question not completely noob question!!
    By Lastremanent in forum Introductions/Noob Questions
    Last Post: 06-11-2013, 05:18 AM
  2. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  3. LTFTs changed, why?
    By Juanmiguel in forum PCM Tuning
    Last Post: 04-16-2011, 02:38 PM
  4. LTFTs at -22.06
    By 2001GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2010, 12:22 PM
  5. stuck in open loop and LTFTs pegged at 0.0%
    By fst in forum PCM Tuning
    Last Post: 05-02-2008, 08:57 AM
