Thread: Engine Monitoring/KR/Ignition timing on a Windows Phone
Results 1 to 8 of 8
  1. #1 Engine Monitoring/KR/Ignition timing on a Windows Phone
    Oct 2012
    Central FL
    Using an Elm327, and a Windows Phone, I have an app that allows me to see ignition timing, but haven't found one yet that actually shows KR.
    Question is, is there a way to see if I'm getting KR? I know that when I step on the gas heavy, that my timing decreases, but I understand that it's supposed to decrease when under boost?
    Long story short, Is there a way to tell if I'm effectively eliminating my Knock Reduction by just monitoring the ignition timing?
  2. #2 Re: Engine Monitoring/KR/Ignition timing on a Windows Phone
    Florida
    unless you know what exactly the timing should be, then no. if you are just able to only scan timing it will not show you much. timing decreases as rpm increase and also decreases as air flow increase. temp and commanded air fuel will also effect your commanded timing. there are many different tables that effect timing. with the minimal data you are seeing it will be basically impossible to calculate if you actually are seeing KR.
    I am in the daytona area. if you need help learning to tuning or data logging you can swing by some time. if you want tuning PM me.
  3. #3 Re: Engine Monitoring/KR/Ignition timing on a Windows Phone
    GT Level Member cmal37's Avatar
    May 2011
    Tampa FL near USF
    What app are you using? I have a windows phone. I use my tablet in the car though and run the Torque App
    Sent from my Lumia 900 using Board Express
    GMPP Struts, F body brakes, CAI, Ubend, resonator, and cat delete, 180tstat, SD headers, 3.4 Pulley, OverKill PCM,http://www.grandprixforums.net/my-bl...res-60017.html
  4. #4 Re: Engine Monitoring/KR/Ignition timing on a Windows Phone
    Oct 2012
    Central FL
    I've tried two. OBD Auto Doctor, and AutoDash. I like AutoDash's interface better, but Auto Doctor gives a lot of info, just neither of them do KR. Hoping to influence Auto Doctor.
  5. #5 Re: Engine Monitoring/KR/Ignition timing on a Windows Phone
    Oct 2013
    NC
    Find a used cheap Android phone (with wifi) and get the Torque App. It will display KR but you will have to set it up. YouTube vid showed me how.
  6. #6 Re: Engine Monitoring/KR/Ignition timing on a Windows Phone
    GTP Level Member
    springfield IL
    Anything for an iOS system????
  7. #7 Re: Engine Monitoring/KR/Ignition timing on a Windows Phone
    There is an app in the App Store called Rev iirc, it costs something like $30 and I guess its not that great of an app, at least back when I last looked at it anyway.
  8. #8 Re: Engine Monitoring/KR/Ignition timing on a Windows Phone
    Donating Users timboku's Avatar
    Montgomery, IL
    Torque app is the best and onl 4.99..andriod rocks...windows and IOS cant get anything good...
  1. Strange engine tic at low idle. Timing chain hardware, valvetrain?
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-14-2012, 07:15 AM
  2. car is cutting ignition timing
    By BlackGT97 in forum General Tech Discussion
    Last Post: 12-30-2011, 10:51 AM
  3. Engine Bay Ignition Wire?
    By chamilton89 in forum Audio, Security & Visual Electronics
    Last Post: 03-02-2011, 02:24 PM
  4. Ignition Timing off on my Overkill?
    By 04CompG in forum PCM Tuning
    Last Post: 11-01-2008, 09:46 PM
  5. Engine Guru's, Help Me Understand Ignition Timing
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2008, 04:28 AM
