Thread: How big of a cam is allowed with stock heads?
Page 3 of 3 FirstFirst 123
Results 41 to 49 of 49
  1. #1 Re: How big of a cam is allowed with stock heads?
    TDCRacing
    Guest
    I will have a gen 5 i do have a shift kit with 3.29's. I also have a 78mm tb.
    That's gotta help something.
    Guess that adds anothe possibility
  2. #2 Re: How big of a cam is allowed with stock heads?
    TDCRacing
    Guest
    Other than that he has almost the exact same setup that i will have....Compression ratio and all.
  3. #3 Re: How big of a cam is allowed with stock heads?
    Donating Users chrisb's Avatar
    Bucyrus, OH
    i know he put a gen 5 on but didnt get any times with it on. it prolly would have gone 11.8. have you looked at the zzp aluminum heads?
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  4. #4 Re: How big of a cam is allowed with stock heads?
    TDCRacing
    Guest
    yeah and i've done some reasearch and the is4 heads from intense and the aluminum ones flow almost the same. The only difference is the exh port on the zzp head flows less than the one on the is4 head... and for getting the exact same head (same valves ect) that intense has i'll do my own port work to make them flow just as good(just bought some stock ported heads with bigger valves). even if i dont i got them for almost 2000.00 cheaper...It is not worth it to me to get aluminum heads and not gain much hp at all and waste 2000 dollars.
  5. #5 Re: How big of a cam is allowed with stock heads?
    Bucyrus, OH
    ok yeah i couldnt agree more, unless they were like 1000 or so. i didnt know if you were a person who had the money to buy them or would take the time to port a set yourself. i like to do the work myself i would say is3 or the xpz would be your best bet on the cam. and how streetable is the xp cam? gas mileage?
  6. #6 Re: How big of a cam is allowed with stock heads?
    TDCRacing
    Guest
    Xp cam...perfectly streetable. I think anything can be streetable with tuning but im not sure.
    I just can't see where a cam with high lift will hurt me any as long as i have the engine work to back it up. Such as Higher compression (wich i will have 1:2 aprox more than stock) port work and Because of the power adder that i will be running and the amount (125 shot Max) also considering that I will have Bigger intake and exhaust valves installed in the heads......
    And for the fact that the m90 likes a high intake lift cam and nitrous likes the opposite....
    IS4 It is.
    Enless some one can give me some facts why they don't think it a wise choice for my combo.
  7. #7 Re: How big of a cam is allowed with stock heads?
    ^^^ that is who i bought those heads from, shawn mayes. he said the heads im selling you are better than his.
  8. #8 Re: How big of a cam is allowed with stock heads?
    Aug 2008
    Flushing/Flint, MI
    The reason I say Exhaust bias and Intake Bias is that a M90 likes a cam bigger on the intake to ram the air in without blowing it through the cly. This has little to do with the lift you need to look at duration a LSA. To much overlap and you will blow most of the boost right out the exhaust valve before it closes.
  9. #9 Re: How big of a cam is allowed with stock heads?
    TDCRacing
    Guest
    Well as far as the LSA goes I belive it is the same as the xp. I know it's very close. I belive the xp is 116 and the is4 is like 115.
  1. Stock stereo backlight inop? Which speakers to replace stock?
    By Z28 in forum Audio, Security & Visual Electronics
    Last Post: 12-04-2008, 11:47 PM
  2. No Private Messaging allowed for me
    By Egleone6 in forum Forum Bugs/Suggestions
    Last Post: 06-03-2008, 12:55 PM
  3. heads for a gt
    By Grandprixboy1224 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-06-2008, 11:21 PM
