They acomplish the added clerance by milling down the valve retainers and shorter valve seals. To do it right you should mill the valve guides.
Also to answer your first question , I dont think you can run that with out taking the heads off and having work done. That is quite a bit of lift... i belive it is or is similar to a IS4 cam so i would check to see what they say it needs
