PB Blaster and a torch are your best friend. Heat the bolt/nut for a minute or so, then soak with PB, repeat unti desired results are achieved.
And yes, you should be able to pull the whole rear section out, though it is much easier pulling it out 1 piece at a time.
Thanks I'll try that
Quote Originally Posted by Iceman6669 View Post
I used a hack saw and cut mine in half.
Where did you used the hack saw at?
Down near the flex? Or a little up close the o2 extension
Sent from my SAMSUNG-SGH-I747 using Tapatalk
