Thread: Coolant never changed 140000 running hot
Results 1 to 4 of 4
  1. #1 Coolant never changed 140000 running hot
    GT Level Member Xanthous's Avatar
    Apr 2011
    St. Louis
    Just picked this car up and it's running hot, checked the coolant and it looks bad/rusted. I put a new thermostat in last week and bled it but it runs warmer now. I'm going in for a coolant flush tomorrow, do you have any recommendations? Things I should look at?
    Hoping it's simpler than a headgasket.
    Thanks, Justin.
  2. #2 Re: Coolant never changed 140000 running hot
    Florida
    Well, with it looking rusted, the whole cooling system is probably gummed up.
    Have it flushed and filled with regular green coolant, and bled properly. (The running warmer after messing with the cooling system is usually do to air still trapped in the system)
  3. #3 Re: Coolant never changed 140000 running hot
    I'd drain it and fill it with water and then go drive it for a while to cycle it all throughout the system. Do that 1-2 times and then add new coolant.
  4. #4 Re: Coolant never changed 140000 running hot
    Apr 2011
    St. Louis
    I did some homework and I'm having water pump symptoms. That makes sense with the rusted coolant. Taking it in to get a flush and water pump today, hopefully that resolves things.
  1. Running Warm after Coolant flush
    By Lishap in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-01-2013, 09:39 AM
  2. Do both coolant elbows need changed with a lim job?
    By dsmuts in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-31-2012, 05:43 PM
  3. Loosing coolant, engine running hot and rough
    By larsol1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2011, 05:38 PM
  4. running hot and lossing coolant
    By gtp40th in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2010, 02:56 AM
  5. Car is running like ass with muddy coolant
    By intervention in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-16-2009, 05:42 PM
