Also I have no idea how to replace engine mounts ... it spikes to like 10 when I initially start moving not sure why probably bad mounts lime you say
Don't worry lol it's not the end of the road.
Mine will return to a DD once a finish a few things, and reregis it etc probably be back on road next year.
It's simple. Jack, jack stands, piece of 4x4 and most importantly beer.
There's a write up in the how to section ill link it later for you if you don't find it.
Understandable. I would still get poly for the strut mounts..makes a huge difference. Flipping them is free but poly still made more of a difference. The poly dogbone mounts aren't necessary. The rubber ones are fine and guys tend to have issues with noise and vibrations with them not to mention getting them in.
Oh and flip your sway bar when you do the downpipe. Gives more room between the downpipe and the sway bar so that it doesn't touch each other and cause false knock.
