Thread: Car died then wait then start then drives then dies - Repeat, wth?
Results 1 to 20 of 26
  1. #1 Car died then wait then start then drives then dies - Repeat, wth?
    Cambridge, Ontario Canada
    Came off a very quick (5-6 second WOT run) & car dies completely. I pulled over & car wouldn't start, 10 mins goes by & car fires up but idle is wild. I put in gear & proceed to drive another 5 mins when car dies again. I repeat that 3 more times before I get home. I also did notice at one time during the driving that the TCS light stayed on. Another time it didn't. Anyone experience this or where to start? I am hoping fuel pump or something?
    No codes either
    2005 E55 - stock
  2. #2 Re: Car died then wait then start then drives then dies - Repeat, wth?
    I'll start by checking your fuel pressure
    04 Comp G.
  3. #3 Re: Car died then wait then start then drives then dies - Repeat, wth?
    Could be cps
  4. #4 Re: Car died then wait then start then drives then dies - Repeat, wth?
    That too
    04 Comp G.
  5. #5 Re: Car died then wait then start then drives then dies - Repeat, wth?
    yup, what they both said.
  6. #6 Re: Car died then wait then start then drives then dies - Repeat, wth?
    Don't have a FP gauge but I was thinking of doing the FP resistor bypass for starters?. Wouldn't CPS throw a code?
    2005 E55 - stock
  7. #7 Re: Car died then wait then start then drives then dies - Repeat, wth?
    CPS normally doesn't throw a code
    04 Comp G.
  8. #8 Re: Car died then wait then start then drives then dies - Repeat, wth?
    crank sensor almost never sets a code.
    you can get the free rental deal for a fuel pressure tester.
  9. #9 Re: Car died then wait then start then drives then dies - Repeat, wth?
    I have a vacuum pressure gauge, will it do FP as well? It has a hose with a plastic fitting. Will that work on GP's?
    How do you test the CPS?
    2005 E55 - stock
  10. #10 Re: Car died then wait then start then drives then dies - Repeat, wth?
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Quote Originally Posted by Elite6 View Post
    A vacuum gauge will not work to test fuel pressure. You need an actual fuel pressure gauge. To test the CPS you need a logic probe. You the pin the CPS input on the ICM and turn the engine over and see if the light it blinking. (You have to do this when the car won't start)
    I went NA when a whore left -$300 in my bank account.
  11. #11 Re: Car died then wait then start then drives then dies - Repeat, wth?
    Remember Scotty he's in Canada so no autozone, advance etc I believe.
    04 Comp G.
  12. #12 Re: Car died then wait then start then drives then dies - Repeat, wth?
    BOOOOOOOO, the parts stores must be almost as cool as ours here in the states ehh?
  13. #13 Re: Car died then wait then start then drives then dies - Repeat, wth?
    Healthcare > rent a tool lol
    04 Comp G.
  14. #14 Re: Car died then wait then start then drives then dies - Repeat, wth?
    Feb 2013
    37.295091, -121.930053
    Love my rental tools I have a FP gauge :-P
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  15. #15 Re: Car died then wait then start then drives then dies - Repeat, wth?
    Car seemed to start up & run fine for little stints + I bypassed the low speed pump & no dice still. I just replaces the CPS & now the car wont start at all. I kept it running for about 3 seconds just barely. Don't tell me I have to get this towed to the dealer/shop?
    2005 E55 - stock
  16. #16 Re: Car died then wait then start then drives then dies - Repeat, wth?
    I decided to replace the CPS given it was an easy job, car won't start at all now. Wondering if a case learn is needed now?
    2005 E55 - stock
  17. #17 Re: Car died then wait then start then drives then dies - Repeat, wth?
    Push the Schrader valve on the fuel rail. Does fuel come out?
  18. #18 Re: Car died then wait then start then drives then dies - Repeat, wth?
    Yes.
    Progress: I pulled the MAF & car started & ran. I shut car off started with MAF plugged in, it ran for 10-15 seconds & died. Dead or dirty MAF?
    2005 E55 - stock
  19. #19 Re: Car died then wait then start then drives then dies - Repeat, wth?
    Jan 2012
    Indianapolis
    You need to replace your MAF or just run with it unplugged. (Gas mileage will suffer some without it)
    You could try cleaning it with MAF cleaner but I doubt it will help if it's so bad that the car can't run with it plugged in.
  20. #20 Re: Car died then wait then start then drives then dies - Repeat, wth?
    Yep maf is dead
  1. 99 Grand Prix GT Died and won't start
    By Smoothtone in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-01-2012, 10:44 AM
  2. Motor died - multiple error codes - clueless where to start looking
    By Skrappi69 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-17-2011, 08:10 AM
  3. Car died and will not start
    By gofast84 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-11-2011, 11:25 PM
  4. 97 3.1L wont start, stumbles and dies
    By atxjax in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-16-2010, 03:18 AM
  5. 2003 GT Won't Start when Engine is Warm...have to wait 45 min
    By LS2 GTO in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-17-2009, 12:30 PM
