To make a long story short my 2000 Gtp would start running rough and throw a flashing check engine light only after you would start it up and drive it when it was warm (for example I would drive it home from work for lunch and then thirty minutes later I would go out to start it and it would run junky). However on cold starts it would run just fine. So I decide to park it until I can order LIM gaskets (the car had pools of oil in the intake manifold "valleys"). My mom apparently decided she wanted to drive the car after I advised her not to. So I came home from work and my mom tells me she drove the car three times and that each time she drove it it ran like junk cold or not. Since that day no one had driven the car.
Well today I finish the LIM job. I went ahead and changed the oil and filter and put some coolant in it and decided to start it up. It ran ok for three seconds and then started making a knocking sound coming from what sounds like the passenger front side of the engine. So initial thought is maybe the supercharger coupler went out while it was sitting or something so I removed all the belts and started it again. Still same sound. I guess what I'm trying to ask is, does it seem possible that it threw a rod? When I drained the oil for that first start there were no metal shavings or anything in the oil and I did not see any traces of coolant either.
Where do I start? Would be a shame to throw the car away based in the premise of a possible thrown rod especially since the PO had a new tranny, steering rack, half shafts, struts, and other odds and ends replaced including tires, plus the car is pretty clean rust wise as well.
