Thread: Rod Knock?
Results 1 to 15 of 15
  1. #1 Rod Knock?
    Nov 2011
    Omaha, NE
    To make a long story short my 2000 Gtp would start running rough and throw a flashing check engine light only after you would start it up and drive it when it was warm (for example I would drive it home from work for lunch and then thirty minutes later I would go out to start it and it would run junky). However on cold starts it would run just fine. So I decide to park it until I can order LIM gaskets (the car had pools of oil in the intake manifold "valleys"). My mom apparently decided she wanted to drive the car after I advised her not to. So I came home from work and my mom tells me she drove the car three times and that each time she drove it it ran like junk cold or not. Since that day no one had driven the car.
    Well today I finish the LIM job. I went ahead and changed the oil and filter and put some coolant in it and decided to start it up. It ran ok for three seconds and then started making a knocking sound coming from what sounds like the passenger front side of the engine. So initial thought is maybe the supercharger coupler went out while it was sitting or something so I removed all the belts and started it again. Still same sound. I guess what I'm trying to ask is, does it seem possible that it threw a rod? When I drained the oil for that first start there were no metal shavings or anything in the oil and I did not see any traces of coolant either.
    Where do I start? Would be a shame to throw the car away based in the premise of a possible thrown rod especially since the PO had a new tranny, steering rack, half shafts, struts, and other odds and ends replaced including tires, plus the car is pretty clean rust wise as well.
  2. #2 Re: Rod Knock?
    Nov 2011
    Omaha, NE
    Oh and this one has NO mods.....not even a cai.
  3. #3 Re: Rod Knock?
    St. Louis
    Um, if it threw a rod you would probably have a hole in the block, lol... That said it could have spun a bearing if it was eating coolant that whole time. Time to hit youtube and search for 3800 rod knock and see if it sounds like what you have going on. If you can snag a video of it running with decent audio post it here and we can help. Could just be a lifter.
  4. #4 Re: Rod Knock?
    Nov 2011
    Omaha, NE
    Alrighty then spun bearing. No holes as of yet. If I cant get a video I will just check the oil condition
  5. #5 Re: Rod Knock?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    If its anything like this our problem was a plugged lifter. After it sat for 6 months the sound went away.
    2012 F150 STX
    - Gonna be a race truck
  6. #6 Re: Rod Knock?
    You did a LIM.. hows' the plugs and wires? Are you sure you put the wires in the right order?
  7. #7 Re: Rod Knock?
    Nov 2011
    Omaha, NE
    The wires appear to be fine. I'll have to give the plugs a look when I get off work.
  8. #8 Re: Rod Knock?
    Nov 2011
    Omaha, NE
    Alright well the car stopped making the noise so I finally felt comfortable with letting it warm up so that I could top off the coolant and burn off whatever spilled on the engine. Car died on me three times while warming up but finally got to the point where it was warm so I took it to get scanned for codes.
    P0203- Cylinder 3 Injector "A" Circuit
    P0121- Throttle Position sensor Performance
    P0101- MAF sensor Performance
    P0507- Idle Speed High
    Car likes to fluctuate in idle and stumble and sometimes it likes to run smooth. Also likes to try and die when coming to stops or putting it in gear.
    Oh and like an idiot I completely forgot to get a new vacuum line to run from the MAP sensor to the supercharger "T" to the fuel pressure regulator because somehow I completely lost mine so right now there is nothing there. Could that alone be causing all my issues?
  9. #9 Re: Rod Knock?
    the missing vac line will cause it to idle like crap, stall yes. run poorly, yes.
    the best vac T's ive found were at advance auto, 2 came in a pack for 2 bucks, 2 small white t's, 3 feet for vac line and you should be good to go from the boost bypass vavle to the fpr (new T on that too) then to the port under the snout, then to the map sensor.
  10. #10 Re: Rod Knock?
    Nov 2011
    Omaha, NE
    Alright. I got it hooked up now with some vac line of a jy car and it definitely doesnt stall anymore but I can still feel it missing. Probably has something to do with that 3rd injector code...
  11. #11 Re: Rod Knock?
    May 2008
    Schuyler, NE
    Might just possibly have a bad #3 injector. Look to make sure it's plugged in all the way.
  12. #12 Re: Rod Knock?
    Nov 2011
    Omaha, NE
    Which one is the #3 injector?
  13. #13 Re: Rod Knock?
    May 2008
    Schuyler, NE
    It's on the front bank, middle cylinder.
  14. #14 Re: Rod Knock?
    Nov 2011
    Omaha, NE
    Alrighty yeah its plugged in all the way. Possible bad injector? The car was missing before doing the LIM too.
    You still do tuning right GTPpower?
  15. #15 Re: Rod Knock?
    May 2008
    Schuyler, NE
    Yeah, could be a bad injector.
    And, yes I still tune.
  1. rod knock or something else?
    By mainjet in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2011, 09:46 PM
  2. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
  3. 00 GT rod knock
    By Sameyeam in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-11-2010, 05:57 PM
  4. Knock Knock - What is it?
    By Blown97 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2009, 12:28 AM
  5. bad knock...
    By FooteGTP in forum Introductions/Noob Questions
    Last Post: 06-29-2009, 04:35 PM
