We have a '99 Grand Prix GTP with 225,xxx miles on it. We live in Minnesota. I have a list of things I need to get done on the car before it gets too cold out. So I have a few questions:
1.) I need to replace the coolant elbows, one is cracked. Should I replace them with the aluminum or plastic elbows? From my searching I have found mixed opinions. Im leaning towards the aluminum ones so I dont need to change them again anytime soon.
2.) How many gallons of coolant will I need? I think I read 3 gallons somewhere. Im going to be using the green stuff. And I want to flush out the radiator and engine with the garden hose. The engine block itself holds one correct? If Im right (it doesnt happen too often according to my wife lol), I will need 1 gallon of the pre-mixed 50/50 and 1 gallon of the straight coolant if the block holds of fluid (water) after I flush it out. If I drop the lower radiator hose, will that get more water out of the engine block?
3.) I know a lot of you guys use the lower rediator hose to drain the coolant. The tabs on the actual drain plug broke off, Im wondering how hard it is to raplace the drain plug? I was thinking about replacing it since the radiator is going to be empty anyway.
4.) What brand oil and oil filters does everone recommend? I have been using Valvoline conventional and FRAM. I dont have a NAPA near me but there is an O'reilly just a few blocks away from our house. For the most part the general opinion is that FRAM isnt good and that is what I have been using since its cheap. O'reily carries Microgaurd, WIX, BOSCH, AC DELCO. At least these are the ones in our price range ($6 or less). Should I switch to high mileage, sythetic, sytheic blend, or is the conventional oil ok? A side note, the car does leak a little oil (a little less than a quart every 3,000 miles) from the oil pan gasket and from what I have read, the sub frame needs to be dropped to replace it. Correct?
5.) Is it difficult to change to change the S/C coupler? It sounds like there are marbles in the S/C snout. Is there any other places to get the S/C oil besides the stealership or W-body online store?
I just want to make sure I am doing everything I can maintenance wise to take care of the car. Its our only car right now. So its our work commuter, grociery getter, family hauler (we have 3 kids). But when tax time comes we want to get a second car and this GP will be my work commuter. Our price range will probably be $5000 or less. She wanted a v6 Charger. But she is coming aroound to the '04+ Grand Prix's. But she said it has to be supercharged.
Thank you for taking the time to read my post. Please feel free to leave any tips or suggestions. I can use all of the help I can get.
