Thread: Radiator Drain Plug Question/Options...
Results 1 to 7 of 7
  1. #1 Re: Radiator Drain Plug Question/Options...
    Yup.. as a CT guy, you should have been pulling the lower radiator hose.. cause that's how we do it in CT. hahahaha
    Seriously though. The help section at your local parts stores should have something on the shelf. It's common to kill it when using it.
  2. #2 Re: Radiator Drain Plug Question/Options...
    SE Level Member Primal's Avatar
    Aug 2013
    Old Saybrook, CT
    Found it! Looks like the right one from here. Sweet that it's got the tabs instead of the socket thingy on it.
    Thanks again!
  1. Small coolant leak. Radiator drain plug
    By eric37428 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-23-2013, 07:42 PM
  2. Radiator drain plug
    By bishdog25 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 10:40 PM
  3. Where is the drain plug located on my radiator
    By ls6velless454 in forum General Tech Discussion
    Last Post: 09-06-2010, 04:16 PM
  4. radiator drain o-ring size? FAILED motormite drain.
    By alacran in forum General Tech Discussion
    Last Post: 04-03-2010, 08:16 PM
  5. Special tool needed for radiator drain plug on 2000 GP?
    By halfwit in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-18-2009, 09:31 PM
