Thread: leak
Results 1 to 20 of 21
  1. #1 leak
    SE Level Member ssiebor14's Avatar
    May 2013
    Biglerville
    Antifreeze leak. Getting low coolant across the speedometer. Leak is coming from the back of the motor. Constant overheating. Having to constantly stop and go due to the fact.
  2. #2 Re: leak
    Nov 2011
    NY
    Thanks for the info.!
    If that was a question... I'd fix leak, refill coolant and call it a day.
    good luck!
  3. #3 Re: leak
    May 2013
    Biglerville
    Yeah but how do you fix the leak. I don't know where it's coming from. Or if it's the water pump that went out.
  4. #4 Re: leak
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Take flash light and see where it is dripping from, follow from there. We can't help with what little if any info you have besides it is over heating. It can be a number of things. First give it a try and find out if you can at least see from what side. Heater hoses, elbows on the lim, water pump, radiator, head gasket, radiator drain plug.
    If You Cant Hear The Whine You're Too Far Behind...
  5. #5 Re: leak
    May 2013
    Biglerville
    Nothing coming from the radiator not the top and bottom hoses are not sucking anything up
    Sent from my HTCONE using Tapatalk
  6. #6 Re: leak
    May 2013
    Biglerville
    I'll check the water pump area
  7. #7 Re: leak
    The issue with being on the internet forum and asking for advice is ..you are our eyes and hands. Telling us.. "there's a leak" doesn't cut it. We need a picture of the wet area, and for you to poke around and find the leak. Once you find the issues or give us pictures.. we can likely head you in the right direction.
  8. #8 Re: leak
    May 2013
    Biglerville
    Okay hold on
  9. #9 Re: leak
    Time passes......
    Time passes.......
    Who know's that reference?
  10. #10 Re: leak
    May 2013
    Biglerville
    First
    leak Attached Images
  11. #11 Re: leak
    May 2013
    Biglerville
  12. #12 Re: leak
    May 2013
    Biglerville
  13. #13 Re: leak
    May 2013
    Biglerville
  14. #14 Re: leak
    May 2013
    Biglerville
  15. #15 Re: leak
    May 2013
    Biglerville
    There you go. I can't really get to far under it with popping of the wheel and getting under the wheel well
  16. #16 Re: leak
    I'm pretty sure this one answers it. See the wet look on the wiring? Check that hose connection right next to where it begins getting wet. Is the piece right there wet?
    Quote Originally Posted by ssiebor14 View Post
  17. #17 Re: leak
    May 2013
    Biglerville
    The hose going done past the power steer res?
  18. #18 Re: leak
    May 2013
    Biglerville
    In the first picture you see where theres ribs on the piece right above the ps res. I stuck my finger inside it and it tasted like coolant. Sorry that a bit weird but I was taught that by a mechanic to tell where a leak is. But is there supposed to be anything connected on those ribs
  19. #19 Re: leak
    See the hose in the picture next the ribs (aka wire loom)? Follow it to the piece of aluminium I think that connection is your leak
  20. #20 Re: leak
    May 2013
    Biglerville
    Okay will do. Sorry it took so long
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
