Thread: Just grabbed another GP, need help with build
Results 1 to 11 of 11
  1. #1 Just grabbed another GP, need help with build
    Jul 2011
    Baltimore, MD
    Just picked up a 2003 Limited Edition GT for next to nothing. Junked my Park Ave Ultra after taking the motor and other things out. Going to be putting that in the LE, which is already pretty much where i want it to be. YT 1.85, 180t-stat, SD Headers, Walbro 255 pump, 3.4 MPS, Gen V, ZZP Wires, SSIC.
    The N/A motor that is coming out i want to build and turbo for my 2000 GT coupe, because i want it completely done there is no rush on it. This past summer i grabbed a XPZ cam and z7 downpipe to get started on the coupe before i found the LE. I will be taking the heads off and sending them to a machine shop locally, because im not paying 1K for ZZP heads...not happening. What else though would i need in order to run the XPZ safely. i heard the guides have to be milled in the heads, but what else im i looking at with this build cam-wise. No rush as i should the LE up and running by mid Nov.
    Going to be doing trans in both cars hopefully by next World Cup Finals at MIR, so those plans are already in the works. assistance please?
  2. #2 Re: Just grabbed another GP, need help with build
    Jul 2011
    Baltimore, MD
    no thoughts??
  3. #3 Re: Just grabbed another GP, need help with build
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    You mean what else is needed to run the XPZ cam and turbo setup?
    Or head wise.
    If You Cant Hear The Whine You're Too Far Behind...
  4. #4 Re: Just grabbed another GP, need help with build
    I'd double check with ZZP on what needs to be done. IIRC it's best to have ported heads with enough lift to handle the cam/pushrods. Keep in mind they have different length rods.
  5. #5 Re: Just grabbed another GP, need help with build
    Jul 2011
    Baltimore, MD
    Yea, tryina to see what else all goes into an XPZ setup. I've read what ZZP has on their site, but i also know their goal is to sell product. So, im looking to see from those who possible have done it, what needs to go into it. I been reading up on the turbo side of my plans and i think i got a good grip on where to go with that, but im sure those questions will arise the deeper i get into it.
  6. #6 Re: Just grabbed another GP, need help with build
    there are far better cam choices with way less work involved unless your set on using a XPZ cam!
  7. #7 Re: Just grabbed another GP, need help with build
    Jul 2011
    Baltimore, MD
    only because i got it so cheap, other i would have preferred to deal with something that didnt require head work
  8. #8 Re: Just grabbed another GP, need help with build
    SE Level Member pontiac4lifesc's Avatar
    Mar 2012
    Winona, MN
    140# springs or higher, some have used 130# springs and have done fine. modded retainers, double roller timing chain, comp cam o-er or ls7 lifters. should measure push rods so you have correct length. zzp's kit comes with 6 7.00 and 6 7.05 pushrods, but as they stated thats with the useof their heads so always measure to be sure.
  9. #9 Re: Just grabbed another GP, need help with build
    Jul 2011
    Baltimore, MD
    Ok, good deal. Whats the deal with the double front covers and machined oil pump cover i read about? Is it necessary or can it be bypassed
  10. #10 Re: Just grabbed another GP, need help with build
    Mar 2012
    Winona, MN
    some people double up timing chain cover gaskets and machined oil pump cover for clearance between the chain and inside the cover, but only really need the machined oil pump cover.
  11. #11 Re: Just grabbed another GP, need help with build
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Do NOT double up on the gasket!!!! I took my crank sprocket to my machine shop and had them chamfer it correctly (like the stock one that came off the car) and I installed the machined oil pump cover. Done....
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  1. kung fu panda (e85 with 2.8 )SOLD
    By TEK310 in forum Members Rides
    Last Post: 04-18-2014, 08:40 AM
  2. Too Slow, Time for a build (GEN V/N*/L32 Lim build)
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2012, 01:54 PM
  3. My new build
    By siLversLeigh in forum Members Rides
    Last Post: 02-23-2011, 02:04 AM
  4. New build.
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2010, 05:44 PM
  5. The Build...?
    By Thunderturd in forum Off Topic Discussion
    Last Post: 11-04-2009, 07:35 PM
