You should be able to drop to at least a 3.0. However every motor is different so the only way to know what is safe for sure is to tune properly and make sure you're scanning.
That's what he's running
Brian's the man
Those retarded bolts are soaking in WD40, but i'm thinking i'll need some heat, or something..[/QUOTE]
IM FEELING THE SAME WAY. I GOT ONE BOLT THAT IS BEING SUPER DIFFICULT N I GOT IT SOAKING WIT PB BLASTER AND WD40. HOPEFULLY IT COMES OUT. DAMN TORQUE HEADS RWALLY SUCK. WHAT ARE BETTER BOLTS TO INSTALL INSTEAD OF THE TORQUES
Instead of TTY?
Studs.
Which studs @blueguy does arp make em or get em from action bolt or someplace like that
WD-40 ain't gonna cut those bolts free....they've got blue thread locker on them. Get a good quality torx bit, and a butane torch to heat the bolts up.
Replace them with a button head bolt to keep it looking good.
Propane definitely works for sure, but I've managed to get them to back out on butane, either is a good choice.
Warning....the bolts come out hard turning....all the way. Which is the reason you will want a GOOD torx bit. If you use a stanely or harbor freight special, it's gonna gnarl the tip and it will likely be useless after only a few bolts.
