Thread: Engine Code P0121 Throttle position sensor
Results 1 to 2 of 2
  1. #1 Engine Code P0121 Throttle position sensor
    Kemmerer, Wyoming
    I've been getting an engine code for the throttle position. I have replaced the sensor 2 times, and the car dosent have any of the symptoms prior to the replacement, but the code still comes back. I also converted over to a North Star tb and N* maf. I had the mechanic check for continuity and voltage for the tps and says its good. is there anything else that could be causing the problem?
  2. #2 Re: Engine Code P0121 Throttle position sensor
    Might be a Scotty fix here.
    Do you have DHP up and running to watch the voltage on it? Or position? Once you do have a way to see it.. wiggle the wiring going over the fans to the engine and also near the tps. Watch for spikes or drop outs.
  1. Throttle position sensor
    By GTPWINDYCITYBOI85 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2013, 04:42 PM
  2. Engine Code Still On After Replacing Crankshaft Position Sensor
    By SlyBlackDragon in forum General Tech Discussion
    Last Post: 08-15-2013, 09:28 PM
  3. Replies: 5
    Last Post: 05-29-2013, 02:15 PM
  4. throttle position sensor
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-25-2010, 11:16 AM
  5. THrottle position sensor
    By xsvtank in forum General Tech Discussion
    Last Post: 11-27-2010, 07:17 PM
