Thread: No spark or Injector Pulse.
Results 1 to 6 of 6
  1. #1 No spark or Injector Pulse.
    Oct 2013
    OHIO
    2000 3.8 s/c
    Getting crank signal. 18x and 3x. ICM has power and ground.
    New parts---
    Cam sensor
    Crank Sensor
    ICM
    PCM
    Ignition Switch
    Coil Packs
    Wiring Harness from ICM to crank/cam sensors.
    i'd have to assume its a wiring issue at this point. Could some one point me in the right direction?
  2. #2 Re: No spark or Injector Pulse.
    Have you checked fuses?
  3. #3 Re: No spark or Injector Pulse.
    Oct 2013
    OHIO
    i have, and i will recheck them tomorrow when it becomes daylight again.
  4. #4 Re: No spark or Injector Pulse.
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    if you changed your pcm you will need a theft deterrent relearn. is the security light on? vtd codes will shut down injector pulse; didn't think it would shut down spark.
  5. #5 Re: No spark or Injector Pulse.
    Oct 2013
    OHIO
    vdt wont shut down spark. already did the relearn. vdt shuts down starter and fuel pump
  6. #6 Re: No spark or Injector Pulse.
    Sep 2013
    Calgary, Alberta
    when you check for power at the icm, use a test lamp. they want to see if it can carry a small load. a dvom won't do that.
  1. no injector pulse?
    By tweeder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-10-2013, 12:14 PM
  2. headlights flicker and pulse.
    By 97gpl36 in forum General Tech Discussion
    Last Post: 07-01-2013, 05:29 PM
  3. How-to add LED's & have them pulse from amplifier
    By mousemonster1232 in forum How To Write-Ups/Tech Tips
    Last Post: 03-17-2011, 06:46 PM
  4. need help asap no injector pulse 5th cyl
    By jenkins6586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2011, 06:47 PM
  5. Pulstar pulse plugs?
    By a98gtp4u in forum General Tech Discussion
    Last Post: 09-20-2009, 08:47 PM
