Thread: still kr w/headers
Results 1 to 20 of 30
  1. #1 still kr w/headers
    Mar 2013
    amherst
    Installed headers sd headers. Nothings touching. Maybe trans dip . A little but not rubbing. The kr dosent come in untill later on. Its not instant closer to when it shifts . ? Also running open headers. No cat or anything.
  2. #2 Re: still kr w/headers
    Cambridge, Ontario Canada
    Pull off S/C belt & go for a rip - see if KR remains
    Also, a tune is paramount
    2005 E55 - stock
  3. #3 Re: still kr w/headers
    Mar 2013
    amherst
    I'm only seeing between 2.75 and 2.35
  4. #4 Re: still kr w/headers
    Open headers?
    Bolt everything up.
    Check mount condition.
    Check for rubbing on sway bar from downpipe.
    Flip upper dog bone mounts for free.
    2.75* of KR isn't that bad at all, especially if it's on a stock pulley.
    Tune-up should take care of that, really. Especially if it hasn't been done.
  5. #5 Re: still kr w/headers
    Mar 2013
    amherst
    Tune up as in tune or new plugs etc...I just did 180tstat one stage colder plugs. New wires. New coolant, mounts already flipped. And bolt everything as in install catback ?
  6. #6 Re: still kr w/headers
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    Yes, that's what he means.
    I'm still getting Kr as well with stock pulley, 1.9 HS rockers, Intake, colder plugs, Taylor wires, SD headers, flipped mounts, urathane filled motor mount and solid trans mount from a Regal, ported intake, and ported Sc.
    Can't figure it out.
  7. #7 Re: still kr w/headers
    Florida
    Tune... Means PCM tuning. We wouldn't say tuneup we would say they heat range of suggested plug. As for wires stock wires are fine upgrading wires do nothing for performance on these cars. They are for looks, reduced noise on audio systems, and are more durable if you plan to take them on and off a lot.
    one question not answered, what type of fuel have you been using? 89? 91? 93? Have you checked fuel pressure or done a good fuel system cleaning?
  8. #8 Re: still kr w/headers
    Mar 2013
    amherst
    Sunoco 93 Oct. And I don't know of any that really work. A lot of gimicks and I don't wanna waste the money on somethi g that won't work
  9. #9 Re: still kr w/headers
    You need a PCM tune and to verify that your not getting false knock from something rubbing or hitting.
    04 Comp G.
  10. #10 Re: still kr w/headers
    GTX Level Member blackflag's Avatar
    Virginia
    on a light note im running a 3.4 on sd's and 0 kr. something must be hitting or you have some engine issues.
  11. #11 Re: still kr w/headers
    Virginia
    wait.... its not tuned?
  12. #12 Re: still kr w/headers
    Quote Originally Posted by BlackFlag View Post
    That's my question also
    04 Comp G.
  13. #13 Re: still kr w/headers
    Virginia
    Quote Originally Posted by blueguy View Post
    Open headers?
    Bolt everything up.
    i had .5 kr stock on a 100k car.
  14. #14 Re: still kr w/headers
    Virginia
    so, are you on the stock pulley?
  15. #15 Re: still kr w/headers
    Pennsylvania, USA
    Lower motor and trans mounts you didn't mention if they're in good condition. See if they're sticky/wet/gooey, basically if they're leaking hydraulic fluid. And if you're not tuned and are running off a stock PCM, then that is at least contributing.
    As for fueling, have you changed your fuel filter recently? Do that immediately ifyou haven't. For cleaning it I always use Seafoam. A full can with a full tank of gas, and avoid filling up again until you've used most of the tank. I use it once every year after winter to keep things clean.
    An addition, have you ever Seafoamed the car in general? Like sucked in through a vaccuum line, not in the gas tank. I have talked to a few local guys who've eliminated 1-2* of KR doing that. It just cleans carbon deposits off your valves and wherever it gets sucked to, I do that on almost every car I've tuned up for people and it always worked well.
    Quote Originally Posted by Z34Phoenix View Post
    Wait, have you really had experience of better spark plug wires eliminating noise in systems? Not that I doubt you, I've honestly never heard of that. Maybe something to remember when I help diagnose people's systems
  16. #16 Re: still kr w/headers
    Mar 2013
    amherst
    No tune. Stock pulley. Never used seafoam herd u have to change plugs and oil almost directly after you use it
  17. #17 Re: still kr w/headers
    Florida
    Oil change would be a good idea after and depending on how dirty everything was the plugs could be fouled. All the more reason to do the sea foam. I you are using the recommended auto lite plugs they are cheap anyway
  18. #18 Re: still kr w/headers
    Feb 2009
    flintnasty MI
    a "tune" is not going to fix anything.. My car doesnt knock on a stock pulley with a leaner/higher timing tune.
    Might want to investigate extreme fuel trims. Try unplugging your battery for an hour and unplugging your o2 sensor if you have a 97-03 gtp.
  19. #19 Re: still kr w/headers
    Mar 2013
    amherst
    Unplugging. Battery. Got. But for the o2 sensor . Leave unplugged or reinstall ?
    Edit : I'm also only running one 02 atm
  20. #20 Re: still kr w/headers
    Feb 2009
    flintnasty MI
    unplug front o2.. this will disable your fuel trims and let you know how mechanically sound your maf sensor/fuel pressure is... If you get more KR you might want to look in those areas... if you get less or none.. yay?
  1. wtb tog or slp headers.
    By bwc1987 in forum Wanted To Buy - Parts
    Last Post: 08-13-2013, 06:34 PM
  2. Headers
    By JonnyGrandPrix in forum General Grand Prix Discussion
    Last Post: 03-08-2012, 09:48 AM
  3. What to do after headers?
    By bevernden in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-18-2010, 09:26 AM
  4. XS Power Headers Vs. SSAC Headers
    By 04CompG in forum General Tech Discussion
    Last Post: 12-02-2008, 01:12 PM
