Thread: Recomended replacment injector size and source for 2001 GTP
Results 1 to 12 of 12
fisheson Recomended replacment... 10-12-2013, 05:23 PM
Fivefingerdeathpunch Re: Recomended replacment... 10-12-2013, 05:55 PM
fisheson Re: Recomended replacment... 10-12-2013, 08:11 PM
addzradd Re: Recomended replacment... 10-12-2013, 07:13 PM
stealthee Re: Recomended replacment... 10-12-2013, 08:28 PM
Booba5185 Re: Recomended replacment... 10-12-2013, 08:33 PM
16MustangVet Re: Recomended replacment... 10-12-2013, 08:35 PM
fisheson Re: Recomended replacment... 10-12-2013, 09:20 PM
Fivefingerdeathpunch Re: Recomended replacment... 10-12-2013, 10:15 PM
Booba5185 Re: Recomended replacment... 10-12-2013, 10:38 PM
fisheson Re: Recomended replacment... 10-16-2013, 12:22 PM
FordMan77 Re: Recomended replacment... 10-16-2013, 12:35 PM
  1. #1 Re: Recomended replacment injector size and source for 2001 GTP
    SWPA
    160 thermostat is a terrible idea. Put a stock 195 in its place.
  2. #2 Re: Recomended replacment injector size and source for 2001 GTP
    Feb 2013
    Missouri
    This^
    If the engine is having a misfire, a code would be present, have you pulled codes? A bad head gasket doesn't mean you would loose coolant, the head gasket can break in between cylinders and loose compression that way, a compression check is a test for that. I don't think your problem is your head gasket, I'm just giving you that information. I would start by pulling codes and let the PCM tell you whats wrong and where to start troubleshooting. If there are no codes, check for vacuum leaks, and do a full tune up. Plugs, wires, fuel filter, the works.
  1. Replies: 6
    Last Post: 07-04-2013, 09:17 AM
  2. What is the biggest rim size I can fit on my 2001 pontiac grand prix gt coupe?
    By Kevin Ferguson in forum Introductions/Noob Questions
    Last Post: 09-08-2012, 04:33 PM
  3. Recommend me an injector size and plugs
    By PacerSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-31-2010, 07:20 PM
  4. 2001 GTP Exhaust Muffler Size
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-09-2008, 02:44 PM
  5. recomended over from tagp
    By Merlin in forum Introductions/Noob Questions
    Last Post: 06-10-2008, 11:22 PM
