Thread: Recommend me an injector size and plugs
Results 1 to 8 of 8
  1. #1 Recommend me an injector size and plugs
    SE Level Member PacerSS's Avatar
    Jul 2010
    East Bay, CA
    As the topic states, I need a suggestion. I am top swapping when I get back and have a pretty extensive mod list to add on. Since I am noobly when it comes to the boosted side of the world. I need an injector size since I am pretty sure that stock L67's aren't going to cut it. Also need a spark plug suggestion since I don't know what would be good on a boosted motor too. Mod list will be as follows:
    Gen V
    N*
    LQ4 MAF
    Speedbuilt FWI
    ZZP Stage 4 Heads
    Intense Stage 3 Blower Cam(.539/.562 int/exh with 116LSA)
    Meziere Water Pump
    ZZP headers
    Full exhaust with catless DP
    180 drilled T-stat
  2. #2 Re: Recommend me an injector size and plugs
    Jan 1970
    Maquoketa, Iowa
    42.5#'s would probably do it for you on 93 octane. If you want to switch to race gas or anything, I would just go with 65# that way you have a lil room to work with.
    Your probably going to run AL 103's gapped at .04 or lower depending on how much boost you are going to run.
  3. #3 Re: Recommend me an injector size and plugs
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  4. #4 Re: Recommend me an injector size and plugs
    Nov 2008
    Haha posted a little late I guess :P
  5. #5 Re: Recommend me an injector size and plugs
    Jul 2010
    East Bay, CA
    Appreciate it fellas. I don't know how much boost I will be running but I plan on starting off with a 3.4. I think I can get away with that and have it not be a knock monster. I was thinking 3.5 to be safe though. I don't plan on running race gas or E85 as of right now so I think I'll go with the 42.5s thanks again for the advice.
  6. #6 Re: Recommend me an injector size and plugs
    I would think you would be able to run a smaller pulley than that with those heads and that cam.
    Never know though.
  7. #7 Re: Recommend me an injector size and plugs
    Jul 2010
    East Bay, CA
    I figured as much too but with no IC yet and the ***** it's going to be to tune starting off, I thought I'd err on the side of caution before I got too extreme with it. I've got a 2.8, 3.0, 3.2, and 3.4 so I figured I'd start at the top and work my down before it started crying. lol
  8. #8 Re: Recommend me an injector size and plugs
    sounds good
  1. what do you recommend for an air filter
    By Real Ricer in forum General Tech Discussion
    Last Post: 02-21-2010, 02:30 AM
  2. Can someone recommend me some rims for the gtp?
    By jmj4492 in forum General Tech Discussion
    Last Post: 08-21-2009, 10:55 PM
  3. recommend tire size for 17x9 bullitt
    By nemesis in forum Tires & Wheels
    Last Post: 06-19-2008, 03:48 AM
  4. Replies: 16
    Last Post: 03-06-2008, 10:15 AM
  5. Which shift kit would you recommend?
    By oldsman105 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-19-2008, 02:09 PM
