Thread: surging idle
Results 1 to 14 of 14
  1. #1 surging idle
    Jul 2013
    wyoming, michigan
    I have a surging idle and don't know why. Was throwing o2 sensor code so I put in a new o2 sensor and no more code , but still getting a surging idle. Hoping to get some idea's to try an figure out what's going on.
  2. #2 Re: surging idle
    SE Level Member samuelcb409's Avatar
    Galveston, Texas
    mines does it also from time to time i checked all vac, replaced o2 sensor, tps, cleaned the tb put new plugs and wires and still there at random but also feels like it holds back at times
    MODS: 3.0 MPS, CAI, SD Headers w/Custom 3"DP, 160* T-Stat, NGK TR6, Full Size intercooler, #42.5s, Ported LIM & Gen III, LS1 TB w/85mm MAF , s1x Cam, #90 Springs, Intense Pushrods, EGR Delete, Cat and U Bend Delete, Magnaflow Resonator & Mufflers, Fully Built ZZP Trans, 2800 stall Tuned by KHP Peformance
  3. #3 Re: surging idle
    St. Louis
    Maybe check the IAC. That and try cleaning the MAF.
    Since the OP didn't say what year the car is, if it's an 04+ then removing the TB and cleaning it along with the MAF might very well solve the issue.
    samuelbc- what plugs did you install? Hopefully copper or the stock irridiums... Have you checked the "T" under the SC snout? Often they crack and do not show an issue until moved a bit.
  4. #4 Re: surging idle
    Jul 2013
    san diego
    do what im gonna do....sell it and dont bother with it anymore
  5. #5 Re: surging idle
    Quote Originally Posted by saranykm View Post
    Great advice jackwagon! Sell the car and leave the forum then..
    04 Comp G.
  6. #6 Re: surging idle
    Jul 2013
    san diego
    Why you mad?
  7. #7 Re: surging idle
    Why do you still complain? So you had a issue with your car...big deal every car is going to have its fair share of issues. If you rather not replace it and just want to sell it then so be it but don't spread your negativity around here...guys are here to help others not to provide terrible advice like just sell it and be done with it. Not everyone hates their cars and many understand that's parts do fail and need replacing. If you want to complain do so in your own thread not someone else's.
    04 Comp G.
  8. #8 Re: surging idle
    Dec 2012
    Where 4T65E's were born
    Sell the car with problems, buy a new used car with another problem, sell it and buy another used car with another problem. It's a cycle then, only way to stop the cycle it is to fix it.
    Sold.
  9. #9 Re: surging idle
    Jul 2013
    san diego
    Oh I understand how cars can break and need repair. but these cars are more than average. ive read MANY complaints on how these cars have the major stalling issue and we all done the same
    fuel resistor change
    relays
    pumps
    crank sensor
    maf sensor
    pressure regulator
    vaccum lines
    idle control valve
    tune up
    clean tb
    and guess what?! it still happens. people take their car to a dealer/specialist and they still cannot find the problem! why is it that i have to beat the crap out of my fuse box for my car to stay on? you're telling me that this issue is common/normal with cars? i doubt that.
    i had a 94 3000gt that had 199 on the clock and i just replaced the oem clutch.
    im not being negative, just being honest on how its not worth the trouble
  10. #10 Re: surging idle
    Dec 2012
    I know many people with GP's (or 3800/4t65e combo) that are up to 150k + original engine and trans, and not many issues. You cant have a problem, shotgun a bunch of parts, and still blame the car. It's not like all of those parts, and more are all causing one single problem. Something's wrong, one thing. You replaced a bunch of things, and didn't change the issue. Not the car's fault. Did you replace all of those things in attempt to fix the same problem? And if you hitting something truly makes a difference, it's time to inspect all of the connections in the box.
    Sold.
  11. #11 Re: surging idle
    Galveston, Texas
    checked all the vac lines and all are good i used autolite 103 coppers gapped at .50
  12. #12 Re: surging idle
    Jul 2013
    wyoming, michigan
    The vacuum line t is fine and I have a northstar throttle body the was cleaned before I put it on. I had zzp take it for a tsst drive and he said that the oxygen sensor seems to act lazy at idle and low dropping rpms. I have pace setter headers and down pipe withe a brand new denso oxygen sensor in the down pipe, I have no cat so the rear o2 is deleted. By the way the car is a 01 grand prix gtp with a gen v sc, north* tb, air intake, ported heads with 130# valve springs, xp hot cam, double roller timing chain,180 degree t stat, 3.3 zzp mps, and zzp 1.0 pcm plus obviously my headers and down pipe as I stated earlier.Just bought an aeroforce I terceptor gauge yesterday and I'm still learning how to use that and trying to learn what the readings should be at some of the stuff. Hopefully that helps out. It was surging worse then I got ride of an e haust leak and it stopped, but occasionally still does it and it wS causing my car to run rich at first too.
  13. #13 Re: surging idle
    Jul 2013
    wyoming, michigan
    Oh I have autolite 104's gapped at like .53 or .52 or something like that, i cant remember. I'm Going to get some zzp 10.5 mm ignition wires in the near future.
  14. #14 Re: surging idle
    Jul 2013
    wyoming, michigan
    With my 3.3 mps its getting some kr too. Is there anything I can do to help that out too other than dropping pulley size? I run 93 gas.
  1. Surging Idle No Codes
    By WOTFTW in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-12-2013, 11:06 PM
  2. Surging, Stalling at idle
    By def88 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-16-2012, 10:55 PM
  3. Need Help with Surging Idle Problem on GTP
    By markeheiden in forum General Tech Discussion
    Last Post: 02-27-2012, 06:52 AM
  4. Please Help!!! GTP surging idle
    By Damon318 in forum General Tech Discussion
    Last Post: 10-26-2010, 01:05 PM
  5. Surging idle when warm
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2010, 10:21 AM
