Thread: Spun Bearing or Chipped Pistion either way Hole in Block. FIXED PICS OF PISTON
Results 21 to 40 of 51
  1. #21 Re: Spun Bearing or Chipped Pistion either way Hole in Block, now what?
    Dec 2010
    DMV
    Quote Originally Posted by SnowFlake View Post
    Around here you can buy an L26 with lowwwwwwww miles for like 250 bucks.
    Top swap it while it's out. That'd be the cheapest way to go.
    I'd be more concerned about why your motor popped after the PCM swap though... Who's to say that's not gonna happen again?
    That's what I want to know, seems a bit odd unless it was a very bad tune
    Sent from my HTC One using Tapatalk 2
  2. #22 Re: Spun Bearing or Chipped Pistion either way Hole in Block, now what?
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Quote Originally Posted by tms8582 View Post
    Typically rods don't break on either motors anyway the rod bolts do. I hear ya about the GenV being a nice upgrade tho.... but sounds like he found a fair priced low miles L67 and is having a hard time finding a l32 in his price range...
    I wish you were right!!!!! LMAO
    http://i698.photobucket.com/albums/v...4-12163521.jpg
    Back side
    http://i698.photobucket.com/albums/v...4-12163534.jpg
    What wasn't attached to the crank
    http://i698.photobucket.com/albums/v...4-13192807.jpg
    If you gonna break it........ BREAK THAT SHIZ... LOL
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  3. #23 Re: Spun Bearing or Chipped Pistion either way Hole in Block, now what?
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    Needs a little TLC but hopefully a new heart for the GTP
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  4. #24 Re: Spun Bearing or Chipped Pistion either way Hole in Block, now what?
    GTP Level Member tms8582's Avatar
    Washington Michigan
    That motor looks really clean compared to some that I've seen. Great find! You will find out soon how the inside looks with the oil pan, ,lim and valve covers off. Hopefully the previous owner changed the oil often and it will be clean inside too. I see the coil packs and engine mounting bracket is missing however...
  5. #25 Re: Spun Bearing or Chipped Pistion either way Hole in Block, now what?
    Washington Michigan
    Quote Originally Posted by dbextreme View Post
    Back side
    Looks like the rod didn't break until it didn't have an intact piston anymore!
  6. #26 Re: Spun Bearing or Chipped Pistion either way Hole in Block, now what?
    I live here. TLSheff's Avatar
    ^ Not to mention the nipple broken off the BBV, the nipple broken off the PCV tree, and probably some other busted up pieces. Scrap yard places don't care about the accessories, they just cut wires and hoses and pull the motor the easiest way they can.
    Just swap over all the sensors and parts you know work and new seals/gaskets for everything you swap. New PCV would be my recommendation as well since they are only a couple bucks.
    It IS a really clean motor tho, mine was dirty as **** and needed cleaning and some spray before it went into the engine bay. I'm a little OCD tho.
  7. #27 Re: Spun Bearing or Chipped Pistion either way Hole in Block, now what?
    Nebraska
    yeah I'm just swapping the top end of the blown one onto the new. Should I swap oil press and KR sensors and such? Also this engine didn't come with a flex plate, I have heard of people having vibration problems when swapping engine to engine without knowing there old position, is this true?
  8. #28 Re: Spun Bearing or Chipped Pistion either way Hole in Block, now what?
    Washington Michigan
    I'd take a good look at all the upper end parts off that new motor because it looks pretty good. How many miles on the blown engine? As far as the sensors go I'd use the better looking of the two imo... just make sure to save the ones you don't use just in case you need them in the future. The flex plate only goes on one way. The 8 holes look even but they aren't so it will only line up in the correct position. You should be good with your old flex as long as its in good shape. Make sure to get torque specs on everything before you start assembling and find out which of your old bolts are one time use. I use ARP bolts on my flex.... not sure if you can re-use the stock flex bolts or not...
  9. #29 Re: Spun Bearing or Chipped Pistion either way Hole in Block, now what?
    Nebraska
    Blown has 87k on the clock, I figured Id use some lock tite on the flex bolts but if I need to replace them I will. Engine is ready to pull minus 4 18mm engine to trans bolts. This is where I left it. http://
  10. #30 Re: Spun Bearing or Chipped Pistion either way Hole in Block, now what?
    Washington Michigan
    Wow the old motor had really low miles. Like snowflake posted I'd really be cautious with that pcm and protect your new motor and hard work with a scan gauge.
  11. #31 Re: Spun Bearing or Chipped Pistion either way Hole in Block, now what?
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    I was under the impression they were forged. I know they are improved over the L67 rods but they could be Powdered Metal.
    I don't have anything info that tells me how they were made at the dealership.
    pm rods are sinter forged
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  12. #32 Re: Spun Bearing or Chipped Pistion either way Hole in Block, now what?
    Nebraska
    Whats your guys opinion on ZZPs PLOG front header? Cant afford headers all the way around right now but I want to do everything I can to prevent popping a piston again.
  13. #33 Re: Spun Bearing or Chipped Pistion either way Hole in Block, now what?
    Its better than nothing, thats for sure.
    A 3in downpipe would help too, I'd do 3in downpipe first, then add the plog.
  14. #34 Re: Spun Bearing or Chipped Pistion either way Hole in Block, now what?
    Nebraska
    3" cat-less DP is in the mail on the way. PLOG it is, Is it very difficult to install while engine is in?
  15. #35 Re: Spun Bearing or Chipped Pistion either way Hole in Block, now what?
    Both are easy to install.
  16. #36 Re: Spun Bearing or Chipped Pistion either way Hole in Block, now what?
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Should have just saved up for headers.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  17. #37 Re: Spun Bearing or Chipped Pistion either way Hole in Block, now what?
    Depends on how far he plans to go on the build. If staying for a typical 3.4 pulley with rockers a 3" DP and Plog would be fine. If you plan to go smaller, cam, intercooler and all that jazz, you will want headers.
  18. #38 Re: Spun Bearing or Chipped Pistion either way Hole in Block, now what?
    Nebraska
    I know you said it only goes on one way but It looks like the bolts line up no matter what the direction of the flex.
  19. #39 Re: Spun Bearing or Chipped Pistion either way Hole in Block, now what?
    Washington Michigan
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  20. #40 Re: Spun Bearing or Chipped Pistion either way Hole in Block, now what?
    Nebraska
    Thank you for that. But Ive ran into another problem well mabye.. Has the damage been done? 2 intakes are like this.
  1. Spun rod bearing
    By mofford12 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-17-2013, 10:38 PM
  2. spun a bearing??!
    By bmx6454 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-18-2012, 01:14 PM
  3. Spun a bearing
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2009, 12:05 PM
  4. Spun bearing! swap to L26??
    By gixer2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-05-2008, 08:35 AM
