Thread: help where is the pcm located
Results 1 to 4 of 4
  1. #1 help where is the pcm located
    Mar 2012
    RIVERDALE IL
    i have a p1200 and cylinder 2 misfire someone told my pcm might be bad where is it located i have a 97 gtp
  2. #2 Re: help where is the pcm located
    Ocala, FL
    Under the airbox
    However I doubt you have a bad PCM. Don't know why someone would assume that.
    I bet you may have a bad injector. You can move the injector and see if the misfire follows it.
  3. #3 Re: help where is the pcm located
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Better yet, before you pull your fuel rail off and mess with injectors check your plug wires. Also when was the last time you changed plugs? Start easy and then go for the harder stuff... I had a misfire and it was because I had a dry rotted/cracked plug wire. I'd swap coil packs before I pulled the fuel rail off and swapped injectors, seems easier to me. But, cody's right, could be a fuel injector clogged.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  4. #4 Re: help where is the pcm located
    Omaha, NE
    It could also be a bad coil pack.
  1. Where is the thermostat located on a 01 GT??
    By nickdemio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-26-2011, 07:24 AM
  2. Need help knowing where cylinder 6 is located
    By Jbruce in forum General Tech Discussion
    Last Post: 08-17-2011, 03:59 PM
  3. Does anybody know where the IAC sensor or TB screen is located??
    By nickdemio in forum General Tech Discussion
    Last Post: 03-27-2011, 04:10 PM
  4. Hello...and where is my oil drain plug located?
    By mbable in forum Introductions/Noob Questions
    Last Post: 04-06-2009, 12:18 PM
