Ok I tested for voltage at the pump, I have it with key on. I turn have the key turned on with my ear to the top of the sending unit and it sounds like a sick hissing... I prime and prime and prime with just a little poof of fuel to the rail and nothing so I'm assuming I burnt my pump up. Even if not, I'm still replacing it with a better unit AND the hotwire harness. Question is now,
1) I assume I have a non venturi setup based on no bronze nipple?
2) Will a non venturi 255lph be just as good as the venturi setup? I have heard venturi is better since it's submerged in fuel constantly, but I don't want to switch out canisters and am wondering if anyone is running a non venturi setup with upgraded pump?
3) What brand of pump? I have heard walbro pumps can't go below 1/4 tank. I see the Racetronix pump claims to be a walbro so that's out I assume?
4) Anyone use the Intense, WBody store, or ZZP pumps?
Any help would be appreciated.
