Thread: 04 Engine Reduced Power on Rapid Accelleration
Results 1 to 6 of 6
  1. #1 04 Engine Reduced Power on Rapid Accelleration
    Aug 2012
    United States
    04 GTP. If I accelerate quickly - Ding Ding "Reduced Engine Power" and I have to turn off the engine and wait a minute. Starts right back up and the Check engine light goes off. No problem on regular driving or smooth acceleration. Happened once when on Cruise control in the fast lane and we started up a hill where it applied power. I've cleaned and checked the MAF, throttle body and the air hoses to make sure no leaks or dirt.
    Wondering if the is the throttle position sensor. I read that if one of the 2 position sensors (fuel peddle and throttle body) are off a certain % of voltage, it senses that one of them is bad and it will shut down. Can you tell me if this is true. If so, Ill replace them one at a time and see if it solves the problem.
    Thanks in advance for the help.
    Brent
  2. #2 Re: 04 Engine Reduced Power on Rapid Accelleration
    If the check engine light came on, it set a code that is now stored in the computers memory.
    Get that code and it should help you figure out if its the TB itself or the pedal postion sensor.
  3. #3 Re: 04 Engine Reduced Power on Rapid Accelleration
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    I have gotten this code in a couple of Chevy trucks that use the same type of tb, got that replaced and no more reduced engine power. It has to be within the tb well from my experience it always has been that.
    If You Cant Hear The Whine You're Too Far Behind...
  4. #4 Re: 04 Engine Reduced Power on Rapid Accelleration
    Dec 2010
    ATL,Georgia
    Throttle body for sure! Its the throttle position sensor or butterfly valve messing up. This happened to me although not at full acceleration it would do it during crushing speeds, changed the TB out and bam no more problem
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  5. #5 Re: 04 Engine Reduced Power on Rapid Accelleration
    Jun 2013
    Hollywood ,FL
    I have somewhat the same problen car seems it bogs under heavy acceleration but once car hits higher rpm it opens up and I get full power could that be tps ? If I give it somewhat hard gas it'll bog amd stay at 14.5 afr then oncey afrbgoes to 10 which is too rich it opens up
  6. #6 Re: 04 Engine Reduced Power on Rapid Accelleration
    GT Level Member orange57's Avatar
    Aug 2012
    Chandler, AZ
    I had pretty much the same thing happen, and it turned out to be the pedal position sensor.
  1. Replies: 10
    Last Post: 07-20-2021, 09:07 PM
  2. Reduced Engine Power
    By English05 in forum Engine
    Last Post: 09-04-2013, 12:04 AM
  3. Car saying reduced engine power.
    By Louie3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2013, 06:10 PM
  4. Reduced engine power. Help!
    By Jeremy1279 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2012, 06:54 PM
  5. Reduced Engine Power
    By donpedro_81 in forum General Tech Discussion
    Last Post: 09-22-2008, 07:20 AM
