Thread: French fry like smell?
Results 1 to 15 of 15
  1. #1 French fry like smell?
    Florida
    The past few days ive noticed something in my car has developed a french fry like odor. I have no idea wheres its coming from and before anyone says it no i have not nor anybody else has eaten fries in my car. I notice when im accelerating more so at about part throttle. The only recent things ive done to my car was replace the egr canister and one window motor. Ive blasted the heat and AC to see if its something under the hood and even checked all my fluids but i got nothing. Any ideas?
  2. #2 Re: French fry like smell?
    HUDSON
    Maybe a foreigne object is melting on the exhaust system somewhere.
  3. #3 Re: French fry like smell?
    Florida
    Ill check. It's actually more so now after i accelerate,just tested it out. I wonder what.
  4. #4 Re: French fry like smell?
    Too broken to be broke $$ ntreftz's Avatar
    May 2013
    What the hell is CENLA, Louisiana
    what kind or fuel do you use 86,87,89,91 or 93? my catalytic converter developed an odor with the grade of fuel, I basically had the same issue until I changed to shell's 93
    Poly Uppers, 3.5 snout, HAI, Can Tune, STB, Autolite 606 coppers, 2.5 cattless dp
  5. #5 Re: French fry like smell?
    Florida
    Ive always used hess 93 octane and never smelled this.
  6. #6 Re: French fry like smell?
    May 2013
    hmm. always from the same place?
  7. #7 Re: French fry like smell?
    Florida
    Usually between 3 different stations but when i do go to this particular one ive been to recently it hasnt.given me this french fry odor lol. Well im gonna just ignore it for now and use up this tank and see if its still there when i refill.
  8. #8 Re: French fry like smell?
    May 2013
    when I would use Mapco or citgo fuel mine would I stick with shell v-power 93 and it went away, I thought it was my catalytic converter going bad. turned out to be a big ole nope just bad fuel
  9. #9 Re: French fry like smell?
    Florida
    Well i will say my gas mileage has went up some since then and car feels quicker so it just may be good fuel this time?
  10. #10 Re: French fry like smell?
    May 2013
    lol its a good possibility my car runs like a champ on exon but I cant stand the sulfur smell and its more expensive around here
  11. #11 Re: French fry like smell?
    Oct 2013
    Indiana
    try some seafoam as well that stuff kicks ***. its a fuel treatment btw.
    building a mustang killer one broken bolt at a time.
  12. #12 Re: French fry like smell?
    Sep 2011
    Canada
    Sounds like you have a leaking valve cover. The oil will drip onto the manifold and depending what else you have on there, can cause the smell. Accelerating brings up the oil pressure so more oil will leak onto the manifold. Replace your valve cover gaskets and use degreaser on your manifolds.
  13. #13 Re: French fry like smell?
    Dec 2012
    Where 4T65E's were born
    Also just being curious, were you using your heat when you smelled it? Sometimes if I haven't used the heat in a while, and when I finally do, I smell a burning oil kind of smell.
    Sold.
  14. #14 Re: French fry like smell?
    Florida
    Now that i think about it,it may be my valve cover gaskets leaking cuz just recently changed my plugs and noticed when i did the rears i had a lil oil on my fingers from touching that back rear head area.
  15. #15 Re: French fry like smell?
    Florida
    And no Navy my heat is off each time i smell it.
  1. Amp Gets really hot and smell a burning smell?
    By 2dee11 in forum Audio, Security & Visual Electronics
    Last Post: 09-11-2012, 03:13 PM
  2. Gas smell in Oil in a 98 3.1
    By gpse2000 in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-04-2012, 11:52 AM
  3. Gas smell
    By sammie in forum General Grand Prix Discussion
    Last Post: 04-13-2012, 02:39 PM
  4. oil smell
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2012, 03:31 PM
  5. Bad Smell
    By GMPUNK in forum General Tech Discussion
    Last Post: 07-08-2009, 04:50 PM
