do you drink the well water? if so its ok.
or go buy a crap load of distilled water. its what your supposed to use, dont know anyone who uses it any more.
your whole cooling system is around 3 gallons maybe a bit more. so 6 or 7 gallons of distilled water, 1/2 or that would be used to flush it.
if using bought water, id pull the t stat, and put the housing back on, then run car till nothing comes out, then dump the water in the rad, 1 gallon at a time with it running, and hope its clear by the 3 rd gallon.
once its clear, run it till nothing comes out, then add the coolant, the t stat back in, and top off with the last 3 gallons of water.
Sounds good, I don't drink the water so I will just go for distilled, it's cheap. I heard that running with the heater on will help with the heating block too so I figured that's a good idea, Running after the coolant is drained is okay as long as I had the gallons? Run the car with the drain plug undone to see the water come out, or run and add water, stop car and drain a few gallons at a time?
