Thread: Coolant Preference?
Results 1 to 17 of 17
  1. #1 Re: Coolant Preference?
    SE Level Member ItsMeDc's Avatar
    Aug 2013
    Michigan
    go green.
    do a full flush of the coolant system, drain it, add one gallon of straight antifreeze ( not the 50/50 stuff) top off with water.
    Any car I have ever worked on (mostly my old Cavalier and my sister's Dodge, etc.) have all had green. So you are saying do a full drain with distilled water, and then only add water again? I'm just worried about getting the right mix. I was thinking drain, run water, drain, and then filling with an even mix of the green stuff and water.
    P.S. I have heard if you drain and then just top off with green it should be okay as you will eventually work off the orange with regular changes, but it sounds sketch.
  2. #2 Re: Coolant Preference?
    Aug 2013
    Michigan
    Can I just drain and then top off with the green, hoping there will be little orange left? Which will eventually work itself out? Or should I flush completely in order introduce all green into the engine?
  1. Coolant reservoir has brown junk in it and low coolant light flashing. what is it?
    By JessicaRebel in forum General Grand Prix Discussion
    Last Post: 09-15-2014, 08:37 AM
  2. BOV preference?
    By deadsnake in forum Turbo
    Last Post: 06-01-2013, 02:18 PM
  3. Oil Brand Preference?
    By Eccentric04gt in forum General Grand Prix Discussion
    Last Post: 10-03-2012, 06:45 PM
  4. Oil filter preference
    By 07CrimsonGT in forum General Tech Discussion
    Last Post: 07-24-2009, 07:17 PM
  5. Basic Mod Preference
    By xawahl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2009, 06:41 PM
