When you did the LIM gaskets did you happen to disconnect the battery? If so take it for some gentle drives to let the PCM relearn some parameters. You may have fixed more than just the LIM gaskets (like vacuum leaks) and the ECU is trying to readjust. I'd give it some more miles and then see what you get.
