so update. i changed the sc coupler and it fired up fine ran for a bit then shut off then on again several times, did a test drive all was well. i fired it up again, it wanted to die but i hit the throttle from under the hood and stayed on and worked fine.
could it be a throttle pos sens or fuel filter?
