Thread: Top swap and now a squeal
Results 1 to 5 of 5
  1. #1 Top swap and now a squeal
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    I just top swapped my 04 gp and now it squeals pretty loud. Could it be a bad bearing in the snout of the supercharger? The noise is definitely coming from that area. Thanks,
    Mike
  2. #2 Re: Top swap and now a squeal
    Remove the belt and see if its still there.
  3. #3 Re: Top swap and now a squeal
    GT Level Member mkyota1's Avatar
    Daytona, florida
    If the noise is still there with the belt removed you probly have a vacuum leak.
  4. #4 Re: Top swap and now a squeal
    Oct 2011
    huntley
    Ok cool thanks guys! So if it is the belt should I get a new one?
  5. #5 Re: Top swap and now a squeal
    Daytona, florida
    If the noise goes away with the belt removed it could be a few things like a bad bearing in a pulley, a belt issue, or a supercharger issue. You just need to try to isolate the issue to pinpoint it. Post back up when you are able to remove the belt and hopefully we will be able to help you more.
  1. ARGH, The squeal!!
    By Carpepoon in forum Brakes/Suspension/Chassis
    Last Post: 08-15-2013, 01:43 PM
  2. belt squeal
    By Sandman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2011, 03:10 PM
  3. Brake squeal
    By 04GTPCOMPG in forum Brakes/Suspension/Chassis
    Last Post: 06-15-2009, 12:06 PM
  4. another brake squeal
    By drunknmunky in forum Brakes/Suspension/Chassis
    Last Post: 01-09-2009, 01:41 AM
  5. squeal
    By dbean in forum Brakes/Suspension/Chassis
    Last Post: 10-18-2008, 04:22 PM
