There's almost never a head gasket issue on our cars. Valve cover gaskets would be a issue easy way to find out is take a towel and wipe around the head. Sc gasket shouldn't need replacing unless you've taken off the sc before and didn't replace the gasket or your getting vacuum leaks.
Check if the lim gasket are plastic or aluminum. If you have the plastic ones yes chance them.
