Thread: Need Starting System Schematic for 2000 GP GTP
Results 1 to 4 of 4
  1. #1 Need Starting System Schematic for 2000 GP GTP
    Oct 2012
    Tucson
    I'm having an intermittent starting issue. Once in a while (usually after short drive) I turn the key to start and I get nothing, no click, no lights dimming. In the run position everything is working correctly. I have a new starter and battery. I'm thinking that maybe the ignition switch is going intermittent. It doesn't happen very often. Does anyone have a good schematic showing which fuses, etc. are involved? Thanks.
  2. #2 Re: Need Starting System Schematic for 2000 GP GTP
    missouri
    take a look at the ignition switch/harness- i changed mine out and a lot of problems went away. that switch turns several circuits on everytime you turn the key on. the switch can wear out and cause problems. it caused a problem with my car- the hvac and automatic lights would turn themselves off at random times.
    2000 Grand Prix 3.8 top swapped gt, headers, ported gen 3 blower, 3" catless downpipe, overkilled tune, CAI, 180, transgo shift kit, C5 front calipers, 12" f body rotors, GMPP sway bars, racetronix venturi pump w/rewire. Coming soon: strut braces
  3. #3 Re: Need Starting System Schematic for 2000 GP GTP
    Nov 2013
    Wisconsin!
    Check your grounds
  4. #4 Re: Need Starting System Schematic for 2000 GP GTP
    Your ignition switch feeds the transmission range switch which feeds the stater soleniod.
    If the range switch doesn't allow the power through, it thinks it's not in P or N
  1. 2000 gtp not starting
    By grhein in forum General Tech Discussion
    Last Post: 07-11-2011, 03:36 PM
  2. Anti lock brake system electrical schematic?
    By thirdgenfcarnut in forum Brakes/Suspension/Chassis
    Last Post: 09-01-2009, 03:00 PM
  3. Replies: 2
    Last Post: 07-31-2009, 11:37 PM
  4. Starting to rebuild my System again
    By Hayden in forum Audio, Security & Visual Electronics
    Last Post: 02-06-2009, 05:40 PM
  5. Starting to build my sound system
    By Nick22 in forum Audio, Security & Visual Electronics
    Last Post: 01-28-2009, 05:24 PM
