Thread: Egr w/fsic
Results 1 to 13 of 13
  1. #1 Egr w/fsic
    Dec 2013
    laporte mn
    I was wondering if anyone runs egr with a fsic. I have a 04 comp g and I'm doing a slight build on it but would like to keep some gas mileage while cruising.
  2. #2 Re: Egr w/fsic
    Dec 2013
    ohio
    Mines blocked off. No big MPG loss at all. Didn't even notice.
  3. #3 Re: Egr w/fsic
    GT Level Member 0069GTP's Avatar
    Oct 2014
    Western NC
    Quote Originally Posted by gambler87 View Post
    Someone can correct me if I'm wrong, but my understanding of deleting the EGR when using an intercooler is to prevent carbon deposits from building up and blocking the fins on the core.
    And the EGR system is used to reduce emissions. I can't imagine it effecting gas mileage in any way really.
  4. #4 Re: Egr w/fsic
    Kemmerer, Wyoming
    I have a full size phenolic intercooler and the egr works just fine. had the supercharger off multiple times with no buildup on the intercooler. a properly functioning egr will support higher gas mileage.
  5. #5 Re: Egr w/fsic
    Step #1 throw away EGR and block off the holes...
    Step #2 debate throwing away Intercooler also......... LOL
  6. #6 Re: Egr w/fsic
    Oct 2014
    Western NC
    Quote Originally Posted by SgtMarshal View Post
    I'm curious as to how it will support higher fuel mileage.
  7. #7 Re: Egr w/fsic
    Mar 2012
    NC
    The EGR recirculates spend exhaust gases back into the intake...there's a little unburned fuel in there...so that gets reburned. There's no/very low O2 in the exhaust...that cools combustion temps. Is it a dramatic fuel mileage thing? Nope. Does it do its job? Yup.
  8. #8 Re: Egr w/fsic
    Oct 2014
    Western NC
    Quote Originally Posted by Sven The Baldman View Post
    Eh, maybe by some minuscule amount perhaps, but can't imagine it would be noticeable really. I do know how the system is designed to work, I have a background as a GM technician for 8 years. What part of NC are you at Sven?
  9. #9 Re: Egr w/fsic
    May 2012
    Where winter never ends
    Actually if you look at a tune, when the PCM detects that the EGR is non-functioning it actually takes away a decent amount of cruise timing (~10* IIRC), couple that with the whole unburnt fuel thing and some people can see a good 2-5MPG drop... I did, until I tuned it a day or two later then it was back on par...
    2000 Regal - Winter Beater
  10. #10 Re: Egr w/fsic
    May 2008
    Schuyler, NE
    I would not run an egr with an IC. You will probably lose some mpg's, as stated above, but you really want to keep carbon from building up on your IC core.
  11. #11 Re: Egr w/fsic
    Oct 2014
    Western NC
    Quote Originally Posted by ADecker View Post
    Yeah, I can understand that. Anytime the PCM thinks there is an issue or problem it may change things. I was going on the assumption that if the EGR was deleted it would be done properly and the PCM tuned accordingly.
  12. #12 Re: Egr w/fsic
    Dec 2013
    laporte mn
    OK so the gerenal assumption is take it out, plug the holes, tune ecu. I will do that then
  13. #13 Re: Egr w/fsic
    Let me phrase this differently. You know all that black crud in your SC and on the back of your TB? If you didn't have an EGR, those two would be nearly perfectly clean metal colored.
    You want that crap on your core?
    You want to restrict airflow through your core, more than the core by itself?
  1. Fs: Zzp fsic kit for Gen 5
    By Reptile in forum For Sale - Parts
    Last Post: 03-09-2015, 08:40 PM
  2. Fs: Zzp fsic kit for Gen 5
    By Reptile in forum General Tech Discussion
    Last Post: 03-07-2015, 02:41 PM
  3. WTB - Fsic
    By ILoveAudi in forum Wanted To Buy - Parts
    Last Post: 01-30-2015, 01:26 AM
  4. zzp fsic gen 3
    By byebye04 in forum For Sale - Parts
    Last Post: 10-09-2014, 09:33 AM
  5. Fsic parts
    By kurupt305 in forum Wanted To Buy - Parts
    Last Post: 06-04-2014, 07:15 AM
