Thread: thermostat
Results 1 to 15 of 15
  1. #1 Re: thermostat
    Barksdale AFB, LA
    Quote Originally Posted by silverbulletgtp@msn.com View Post
    hey hows it going had the same problem if you have a 160 or 180 u need to get a code # deleted from the pcm
    A 180* will not require the code to be removed. I believe 160* or 170* is the threshold that the engine has to get to so it doesn't set the code.
    Quote Originally Posted by YoungGTP View Post
    if you choose to not go with a stock then the 180* drilled is the way to go. i can vouch for it as well as webracin can i see. just takes a bit to warm that cargo up haha
    A 180* doesn't change how long it takes your car to warm up. Heater performance isn't really changed either. Drilled thermostats do make your car take longer.
    2009 Subaru Impreza WRX STI
  2. #2 Re: thermostat
    Nov 2008
    Redwood city
    My 2000 GTP with 180 throughs codes. Put the stock back in.
  3. #3 Re: thermostat
    GT Level Member YoungGTP's Avatar
    Aug 2008
    Iowa
    Quote Originally Posted by Sabrewings View Post
    sabring i did say drilled
    -98 GTP Thunderstorm
    Cai, 3.5 press on pulley, NGK TR6's, 3" to 2.5" exhaust, thrush glasspacks, drilled 180 t-stat soon-overkill pcm, fully ported sc, N* TB, and LQ4 MAF, Future- Full I/C, XP cam, s&s headers
  1. is my thermostat not opening?
    By nemesis in forum General Tech Discussion
    Last Post: 10-25-2008, 07:16 PM
  2. Thermostat
    By keenan00gtp in forum General Tech Discussion
    Last Post: 10-20-2008, 05:46 PM
  3. 180 thermostat
    By LMCOOK87 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-14-2008, 03:00 AM
  4. What Thermostat Should I Get ?
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 03-10-2008, 07:00 AM
  5. Transmission Fluid Thermostat
    By Zef_66 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-14-2008, 08:49 AM
