Thread: thermostat
Results 1 to 15 of 15
  1. #1 Re: thermostat
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    I've run 180* on my Imp for over a year, no low temp code. Still going back and forth whether to do the "winter switch" on my thermo on the Imp.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  2. #2 Re: thermostat
    Barksdale AFB, LA
    Quote Originally Posted by Deezul_AwT View Post
    Unless its drilled, why would you need to change it?
    2009 Subaru Impreza WRX STI
  3. #3 Re: thermostat
    Feb 2008
    Cumming GA
    Quote Originally Posted by Sabrewings View Post
    With the colder weather, the car will run cooler, and it won't run as efficient. Gasoline powered engines run most efficient at 195* - that's why that's the standard rate. I put the 180* because of the other mods I did, and I wanted to make sure I didn't burn it out. When I got my GP, I had to replace the thermo. I put in a 180* with zero mods, and a shop that looked it over noted the car was running cool. They thought I had a 160* thermo in it. I switched it to a 195* since I don't have the mods that really require the lower temp one. It was a previous discussion here when I asked if a car could run too cool. I didn't change it last year, so I'm not in a big hurry to do it. What I'd need to do is run the Imp with 180* for a week or so and then again with the 195* I can pull from my GP and compare MPG on both.
  1. is my thermostat not opening?
    By nemesis in forum General Tech Discussion
    Last Post: 10-25-2008, 07:16 PM
  2. Thermostat
    By keenan00gtp in forum General Tech Discussion
    Last Post: 10-20-2008, 05:46 PM
  3. 180 thermostat
    By LMCOOK87 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-14-2008, 03:00 AM
  4. What Thermostat Should I Get ?
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 03-10-2008, 07:00 AM
  5. Transmission Fluid Thermostat
    By Zef_66 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-14-2008, 08:49 AM
