Thread: Does it sound ok???
Results 1 to 14 of 14
  1. #1 Does it sound ok???
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    Ok I know you can't tell by a video but can you give me some answers,does my gp sound ok,here's my vid Does it sound right?? - YouTube
  2. #2 Re: Does it sound ok???
    Where do you hear the sound coming from? Almost sounds like a bad coupler in the SC but I'm listening off my phone so I could be wrong?
    04 Comp G.
  3. #3 Re: Does it sound ok???
    Jul 2010
    That's what I thought,took the belt off and it still does it,I thought it could have been a rocker arm but someone said it can't be,I'm thinking maybe a pulley but not to sure
  4. #4 Re: Does it sound ok???
    Check the tensioner pulleys for play.
    04 Comp G.
  5. #5 Re: Does it sound ok???
    Jul 2010
    How take the belts off and turn them?
  6. #6 Re: Does it sound ok???
    A had a similar issue what I did was take the belt off and then rotate the tensioner pulley by hand and listening and feel for play. I had one that bearings were pretty much non existent. Worth a try and it'll only take you a few minutes.
    04 Comp G.
  7. #7 Re: Does it sound ok???
    Jul 2010
    Ok thanks,how can I tell if any other pulleys may be bad,I just hope the noise ain't to bad or a problem
  8. #8 Re: Does it sound ok???
    Considering I'm guessing the car is still running fine I wouldn't freak out to much. Besides the tensioner pulleys I haven't heard any cases of the other pulleys needing to be replaced but I suppose you can still just check for play with your hand and make sure the bolts that hold them aren't loose. I'm sure others will chime in tomorrow as well as too what the sound maybe.
    04 Comp G.
  9. #9 Re: Does it sound ok???
    Jul 2010
    Ok thanks,when the gas is pressed I think it smooths out but besides the crank sensor I believe it runs pretty good,I think somebody may have took the governor off if that's possible because it dosent seem to quit at 126,if it dosent rain I'm going to go out there and check it all out
  10. #10 Re: Does it sound ok???
    Jul 2010
    It's the coupler or whatever in the sc rattling
  11. #11 Re: Does it sound ok???
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    That's exactly what my wife's sounds like. I'm leaning towards the rotor bearings. I'll find out this weekend.
  12. #12 Re: Does it sound ok???
    Jul 2010
    I swore I thought it was lifters but I'm glad now,I'm buying a rebuild kit,mine ain't bad bad yet
  13. #13 Re: Does it sound ok???
    Jul 2010
    Makes me feel 100 better though
  14. #14 Re: Does it sound ok???
    Jul 2010
    My question is do they make a gasket and how many ft pounds do I torque it to,I don't want to crack anything or can I just tighten it enough and feel until it gets snug?
  1. Grinding sound when making sharp left and awful creak sound when going over bumps
    By rescuetoaster in forum Brakes/Suspension/Chassis
    Last Post: 03-04-2012, 10:06 PM
  2. name that sound
    By jdmgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2010, 11:46 PM
  3. how to get more sound out of s/c?
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2010, 01:31 PM
  4. sound
    By cletus in forum Audio, Security & Visual Electronics
    Last Post: 07-29-2009, 06:50 AM
  5. what should i do to get this sound?
    By bhrfpa11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2008, 07:22 PM
