I was the one doing the engine work.
It was taken to my shop to do this work!!!
I found that the LIM on your car was ported too much for just a blower there was a gap/hole
torwards the snout.
Now this would be fine if there was a ic covering said hole alowing no leaks!
But this was not the case.
I had a brand new LIM in the shop i said i would install, and i do not reuse a LIM gasket
that i did not install due to did it get over torqued,proper torque sequence,was the old lim warped at all?
I stand behind my work and like to do it once. Not go back and redo work because of a cheap gasket..
Also when i heard about you acting like a child i decided i did not want your vehicle on my property.
So it is what it is you wanted a car fixed for damm near free.
Sorry but if you would have handled things better on your end i could and would have worked with you.
