What he meant was that the 180 does little unless you tune it in on the PCM... If you tune it in that the fans turn on at lower temp, along with the sat opened for flow, you might run a few degrees coolerhehe... Pulley drop huh? Hmmmm... With just a DP... Ok, but to each his own. Good Luck!
