Thread: oil pan gasket leak
Results 1 to 11 of 11
  1. #1 oil pan gasket leak
    Oklahoma
    This was a GM screwup, I just found out. Their solution was to gob RTV on both sides of a new gasket and call it "fixed". I'm not inclined to do that but I wonder if the Felpro aftermarket replacement works any better than the OE part?
  2. #2 Re: oil pan gasket leak
    what year car you got there?
    thats how you do it, rtv both side of the gasket on the 97-03. 04 up get no gasket at all.
    is it leaking? valve covers leak and look like a oil pan, rear seals leak, also can look like a oil pan leak.
  3. #3 Re: oil pan gasket leak
    My 04 has a gasket. I used no rtv and it doesn't leak at all
  4. #4 Re: oil pan gasket leak
    you got the al pan? thats the one that dont take a gasket. just sealant.
    rtv shouldn't cause a leak, id bet they use rtv to make sure its sealed up good. its not a job you want to do twice.
  5. #5 Re: oil pan gasket leak
    Steel pan
  6. #6 Re: oil pan gasket leak
    Oklahoma
    I bought this 1997 GTP new. Back rocker cover leaked and I fixed that. I've power washed the underside clean. Oil hangs from the screw heads in the middle along both sides of the pan but not on the screws at the left/right ends. So I'm pretty sure the pan leaks. I need to remove the plastic piece hiding the flywheel and wash that to get a better idea about the main leaking.
  7. #7 Re: oil pan gasket leak
    HUDSON
    Oil hanging from the oil pan bolts is the same thing mine did when the pan gasket was leaking. I replaced the steel pan with the aluminum one use RTV to seal it up, works nice. Although you may get by with just RTV or a new gasket if your pan is not rusted like mine was.
  8. #8 Re: oil pan gasket leak
    Oklahoma
    My pan isn't rusted but if there's a better design that resolves the leak altogether then I'd be inclinded to make the swap. I think the problem will be getting the aluminum pan off in the salvage yard. I'm not sure it'll be worth the effort.
  9. #9 Re: oil pan gasket leak
    HUDSON
    The reason I went with the alum. pan was because my steel pan was rusting, and the gasket was leaking. The cost of a new metal pan and gasket was about the same for the aluminum one, and also I did not want to fight reinstalling the motor mount bracket. Also, The aluminum pan with the RTV is much better at sealing than the gasket.
  10. #10 Re: oil pan gasket leak
    Oklahoma
    Since my old pan doesn't appear to be rusting, I'll stick with it and gob the RTV. Thanks for info.
  11. #11 Re: oil pan gasket leak
    FWIW I've never gobbed the gasket and no..none of the other brands appear to be any better than a stock.
    Gobbing is likely a wise choice though.
  1. Vac Leak... Bad S/C gasket?
    By al2000gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2012, 08:24 PM
  2. Cometic MLS Gasket leak
    By TheGerm in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-07-2012, 06:22 PM
  3. Intake Gasket Leak
    By Iceman6669 in forum General Tech Discussion
    Last Post: 06-09-2011, 11:39 PM
  4. Is this the infamous LIM gasket Leak?
    By hostilehouse in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-23-2010, 08:15 PM
  5. Oil Leak, Which gasket?
    By HOPPY in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-20-2008, 01:07 AM
