Thread: how to tell if u have a 180tstat
Results 1 to 15 of 15
  1. #1 how to tell if u have a 180tstat
    Mar 2013
    amherst
    My gtp runs at about 180° is there a way to tell if the previous owner installed a 180 Tatar??
  2. #2 Re: how to tell if u have a 180tstat
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Put in a stock 195* tstat.
    Takes 2 minutes of your time and $5.
    Plus if you are stock, there is no reason for you to run a 180*.
  3. #3 Re: how to tell if u have a 180tstat
    Take it out and see what it says on it.
  4. #4 Re: how to tell if u have a 180tstat
    Mar 2013
    amherst
    I'm not gnna be stock for long. I have hai . Pulley drop dp and pcm coming this week
  5. #5 Re: how to tell if u have a 180tstat
    Nov 2011
    NY
    What he meant was that the 180 does little unless you tune it in on the PCM... If you tune it in that the fans turn on at lower temp, along with the sat opened for flow, you might run a few degrees cooler hehe... Pulley drop huh? Hmmmm... With just a DP... Ok, but to each his own. Good Luck!
  6. #6 Re: how to tell if u have a 180tstat
    GTP Level Member AjL227's Avatar
    IL
    There is no need to run a 180*.
    Fixed
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  7. #7 Re: how to tell if u have a 180tstat
    Mar 2013
    amherst
    Quote Originally Posted by coolone View Post
    Well a 3.4 press on. 2.5 zap carted dp ubend and res delete. Hai .autolite 605's and a pending tuned pcm
  8. #8 Re: how to tell if u have a 180tstat
    GT Level Member comatoast's Avatar
    Nov 2012
    MN
    Pretty sure your gonna get a ****load of knock. A lot of people with full headers 1.8 rockers and all bolt on supporting mods are getting knock with a 3.6. I had a 2000 ssei and it handled kr better than the gp, and I had all supporting mods and knocked like crazy with a 3.4
  9. #9 Re: how to tell if u have a 180tstat
    Mar 2013
    amherst
    Vetter off getting a 3.6 then ?
    Quote Originally Posted by comatoast View Post
  10. #10 Re: how to tell if u have a 180tstat
    2.5 is wimpy, you want a 3in atleast.
    2.5 his hardly an increase over the stock 2.25in pipe, wont be enough flow.
  11. #11 Re: how to tell if u have a 180tstat
    Florida
    First, 180* stats do have their roll. Down here in florida with the high heat these colder stats do help keep things cooler longer. Cooler engine temps translate into cooler transmission temps and heat is a major cause of damage to trans. Up north the colder Tstat isn't worth it. There is Zero power gain and without adjustments to the fans in the PCM for it it will barely reduce temps even by one degree.
    Next, I agree that a 3.4" pulley is too large a drop with just a down pipe and box pcm. My suggestion is to do headers and find someone local to do an in car tune.
    But before you do any of this, get a scan gauge that you want use every day that displays KR and fuel trims. I like the aeroforce, but i have had the scangauge II also.
  12. #12 Re: how to tell if u have a 180tstat
    Feb 2013
    37.295091, -121.930053
    Quote Originally Posted by t wizzle17 View Post
    boom goes the motor you need more than just a few mods. you need more flow so get with the flow and read the "modding safety" thread.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  13. #13 Re: how to tell if u have a 180tstat
    Yea don't get pulley happy until you have something to scan with. It's much cheaper to buy a scanning device then it is to replace a motor.
    04 Comp G.
  14. #14 Re: how to tell if u have a 180tstat
    Mar 2013
    amherst
    I pln on using the torque pro app ? Is that accurate
  15. #15 Re: how to tell if u have a 180tstat
    St. Louis
    I can't comment on the torque pro app, but if you haven't, please read this thread before you need a longblock....
    http://www.grandprixforums.net/safel...0-a-67580.html
