Thread: transmission and engine wont seperate
Results 1 to 20 of 21
  1. #1 transmission and engine wont seperate
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    Just like the title says I can't get them to seperate, I got the 3 torq converter bolts and all the bell housing bolts and yes I got the one facing backwards.
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  2. #2 Re: transmission and engine wont seperate
    Antioch, IL
    motor mounts use a wrench or screwdriver by the converter opening there are dowl pins in there "holding" it in place
    2009 Challenger SRT8
    Expert at being gay.
  3. #3 Re: transmission and engine wont seperate
    Ok i will try that and yes motor mount is undone
    sold 97 GTP stock
  4. #4 Re: transmission and engine wont seperate
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    now why would you want to separate such a good working combo
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  5. #5 Re: transmission and engine wont seperate
    Quote Originally Posted by 00grandprixgtp View Post
    To make it better porting intake and heads and putting in a vam and all new valvetrain
    sold 97 GTP stock
  6. #6 Re: transmission and engine wont seperate
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    If you got the backwards facing bolt, then you have the bracket between the engine and trans off by the power steering pump too?
    I wouldn't force it it should just fall apart in your lap something is still holding it together.
    97 Bonneville SE Not so much a 97 anymore
  7. #7 Re: transmission and engine wont seperate
    Bracket by power steering pump no that must be it i will un bolt it when i get home never thought there would be one way over there lol
    sold 97 GTP stock
  8. #8 Re: transmission and engine wont seperate
    yup theres a brace between the back of the engine and the tranny, pass side.
  9. #9 Re: transmission and engine wont seperate
    Ya i know the one now i completly forgot about it
    sold 97 GTP stock
  10. #10 Re: transmission and engine wont seperate
    Nov 2009
    Central Jersey
    How did you get the backwards bolt out btw? damn must have been a pain. If you take that bracket off first you can take about a 2' of extension on a 18mm and zip the "backwards" bolt right out.
  11. #11 Re: transmission and engine wont seperate
    I had my headers off so i just got it from up top
    sold 97 GTP stock
  12. #12 Re: transmission and engine wont seperate
    Nov 2009
    Central Jersey
    Ahhh ok. So you got it apart?
  13. #13 Re: transmission and engine wont seperate
    Not yet
    sold 97 GTP stock
  14. #14 Re: transmission and engine wont seperate
    What are you waiting for?
  15. #15 Re: transmission and engine wont seperate
    Been busy porting but its coming out this weekend
    sold 97 GTP stock
  16. #16 Re: transmission and engine wont seperate
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Also a lil tip... Put a piece of wood under the trans pan and jack it up to keep it level and maybe raise the pass side a little higher. When you undo the bracket under the PS pump, then break the bell house loose from the motor the trans will want to "fall" into the motor. If you raise the trans back up, it will make things a lot easier and your flex won't drag on the bell housing as much.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  17. #17 Re: transmission and engine wont seperate
    Everything is allready un done bellhousing im gunna remove ps pump and braket tomorrow
    sold 97 GTP stock
  18. #18 Re: transmission and engine wont seperate
    If you don't support the trans, you typically destroy the CV boot that lands on the subframe.
  19. #19 Re: transmission and engine wont seperate
    Ya im gunna put a jack under it cuz its coming out to so i can degrease the engine bay
    sold 97 GTP stock
  20. #20 Re: transmission and engine wont seperate
    Then why seperate them in the engine bay and pull seperately? That's extra work.
    FWIW you don't need to pull it to degrease. You can do 95% of the bay with the trans in place.
  1. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  2. transmission wont leave 2nd gear...
    By 19GTP98 in forum General Tech Discussion
    Last Post: 01-07-2012, 03:14 PM
  3. transmission wont go into gear
    By eskupperschmid in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-08-2011, 08:40 AM
  4. Transmission wont shift out of 1st
    By topswap in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-22-2010, 08:42 PM
  5. engine trany won't seperate
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2009, 12:23 PM
